Salesforce
Document Stored in Printer's Memory - TR8520
« Go Back
Information
TitleDocument Stored in Printer's Memory - TR8520
URL NameART168410
Description
Print or Delete
Solution
If the sending faxes is not complete or the printer was not able to print the received faxes, these faxes are stored in the printer's memory.
If an error occurred during a fax transmission, the document is not stored in the printer's memory.
In the following cases, the printer is not able to print the received fax and will automatically store the fax in its memory.
  • The amount of remaining ink is insufficient to print a fax.
  • Paper has run out.
  • A different size of paper from that specified by Page size in FAX paper settings is loaded.
  • Do not print is selected for Received documents in Auto print settings under FAX settings.
  • You pressed the Stop button to cancel printing of a received fax.
Important
  • If you unplug the power cord of the printer, all faxes stored in the printer's memory are deleted.
You can print or delete the faxes stored in the printer's memory.
Note
  • When confirming, printing, or deleting a document stored in the printer's memory, you specify it by its transaction number. If you do not know the transaction number for your target document, print the list of documents (MEMORY LIST) first.
    For details on how to print MEMORY LIST, see Printing Document in Printer's Memory
TR8520 Page
Powered by
