Salesforce
Perform Maintenance From a Mac - PIXMA TS or TR Printers
« Go Back
Information
TitlePerform Maintenance From a Mac - PIXMA TS or TR Printers
URL NameART168629
Description
Learn how to open the Remote UI from a Mac so that you can perform maintenance functions on your PIXMA TS or TR printer.
Solution
You can perform maintenance for the printer and change its settings from the Remote UI. Please follow the steps below.
Open Remote UI for maintenance.
  1. Open System Preferences, and select Printers & Scanners.
     If you are using macOS® 13 or later, open System Settings and select Printers & Scanners.
  2. Select your model from the printer list, and choose Options & Supplies...
  3. Select Show Printer Webpage... in the General tab. Remote UI starts.
 The password may have to be entered after Remote UI starts. In such a case, enter the password and choose OK. In case you do not know the password, select About password and cookies.
Depending on your browser or software environment, you may receive a warning that the webpage is not trusted or not secure. If you receive this message, you will need to click Continue or Proceed Anyway (in some situations, you may need to click Advanced first).
If your product issue was not resolved after following the steps above, or if you require additional help, please create or log in to your Canon Account to see your technical support options.
Powered by
