Print the printer's current network settings (LAN Details). An example of the Network Configuration Page for this printer is attached to this article.
Use the operation panel to print the printer's current network settings.
Important
The network settings printout contains important information about your network. Handle it with care.
Make sure printer is turned on.
Load three sheets of A4 or Letter-sized plain paper.
Press the Information button.
The printer starts printing the network setting information.
The following information on the printer's network setting is printed out. (Some setting values are not displayed depending on the printer settings.)
Item Number
Item
Description
Setting
1
Product Information
Product information
1-1
Product Name
Product name
XXXXXXXX
1-2
ROM Version
ROM version
1-3
Serial Number
Serial number
2
Network Diagnostics
Network diagnostics
2-1
Diagnostic Result
Diagnostic result
2-2
Result Codes
Result codes
2-3
Result Code Details
Result code details
http://canon.com/ijnwt
3
Wireless LAN
Enable/Disable
3-1
WPS PIN CODE
WPS PIN code
3-2
Infrastructure
3-2-1
Signal Strength
Signal strength
0 to 100 [%]
3-2-2
Link Quality
Link quality
3-2-3
Frequency
XX (GHz)
3-2-4
MAC Address
MAC address
XX:XX:XX:XX:XX:XX
3-2-5
Connection
Connection status
Active/Inactive
3-2-6
SSID
Wireless LAN SSID
3-2-7
Channel
XX (1 to 13)
3-2-8
Encryption
Encryption method
None/WEP/TKIP/AES
3-2-9
WEP Key Length
WEP key length (bits)
Inactive/128/64
3-2-10
Authentication
Authentication method
None/auto/open/shared/WPA-PSK/WPA2-PSK
3-2-11
TCP/IPv4
Enable
3-2-12
IP Address
IP address
XXX.XXX.XXX.XXX
3-2-13
Subnet Mask
Subnet mask
3-2-14
Default Gateway
Default gateway
3-2-15
TCP/IPv6
3-2-16
Link Local Address
Link local address
XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX
3-2-17
Link Local Prefix Length
Link local prefix length
XXX
3-2-18
Stateless Address1
Stateless address 1
3-2-19
Stateless Prefix Length1
Stateless prefix length 1
3-2-20
Stateless Address2
Stateless address 2
3-2-21
Stateless Prefix Length2
Stateless prefix length 2
3-2-22
Stateless Address3
Stateless address 3
3-2-23
Stateless Prefix Length3
Stateless prefix length 3
3-2-24
Stateless Address4
Stateless address 4
3-2-25
Stateless Prefix Length4
Stateless prefix length 4
3-2-26
Default Gateway1
Default gateway 1
3-2-27
Default Gateway2
Default gateway 2
3-2-28
Default Gateway3
Default gateway 3
3-2-29
Default Gateway4
Default gateway 4
3-2-33
IPsec
IPsec setting
Active
3-2-34
Security Protocol
Security method
ESP/ESP & AH/AH
3-3
Access Point Mode
Operation mode for Wireless Direct
3-3-1
3-3-2
3-3-3
Wireless Direct SSID
3-3-4
Password
Wireless Direct password (10 alphanumeric characters)
3-3-5
3-3-6
AES
3-3-7
WPA2-PSK
3-3-8
3-3-9
3-3-10
3-3-11
3-3-12
3-3-13
3-3-14
3-3-15
3-3-16
5
Other Settings
Other settings
5-1
Printer Name
Printer name
Printer name (Up to 15 alphanumeric characters)
5-4
WSD Printing
WSD printing setting
5-5
WSD Timeout
Timeout
1/5/10/15/20 [min]
5-6
LPD Printing
LPD printing setting
5-7
RAW Printing
RAW printing setting
5-9
Bonjour
Bonjour setting
5-10
Bonjour Service Name
Bonjour service name
Bonjour service name (Up to 52 alphanumeric characters)
5-11
LLMNR
LLMNR setting
5-12
SNMP
SNMP setting
5-13
PictBridge Commun.
PictBridge Communication
5-14
DNS Server
Obtain DNS server address automatically
Auto/Manual
5-15
Primary Server
Primary server address
5-16
Secondary Server
Secondary server address
5-17
Proxy Server
Proxy server setting
5-18
Proxy Address
Proxy address
XXXXXXXXXXXXXXXXXXXX
5-19
Proxy Port
Proxy port specification
1 to 65535
5-20
Cert. Fingerprt(SHA-1)
Certificate fingerprint(SHA-1)
XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX
5-21
Cert. Fingerprt(SHA-256)
Certificate fingerprint(SHA-256)
XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX
6
Bluetooth
Bluetooth settings
6-1
Bluetooth Setting
6-2
Bluetooth PIN Code
Bluetooth PIN code
6-3
Bluetooth Device Address
Bluetooth device address of the printer
6-4
Peer Device Address
Device address of paired device
6-5
Bluetooth Device Name
Bluetooth device name of the printer
("XX" represents alphanumeric characters.)
