Salesforce
Paper Load Limit - PIXMA iP7220
« Go Back
Information
TitlePaper Load Limit - PIXMA iP7220
URL NameART169615
Description
Media Types Limits
Solution
Paper Load Limit
Commercially Available Papers
Media Name
Cassette (upper)
Cassette (lower)
Paper Output Tray
Plain Paper (including recycled paper)*1
N/A*2
Approx. 125 sheets
Approx. 50 sheets
Envelopes
N/A*2
10 envelopes
*3
Canon Genuine Papers
 Note
 We recommend that you remove the previously printed sheet from the paper output tray before continuously printing to avoid blurs and discoloration (except for High Resolution Paper <HR-101N>).
Paper for printing photos:
Media Name <Model No.>
Cassette (upper)
Cassette (lower)
Photo Paper Pro Platinum <PT-101>*4
20 sheets: 4" x 6" (10 x 15 cm)
10 sheets: A4, Letter, and 8" x 10" (20 x 25 cm)
Glossy Photo Paper "Everyday Use" <GP-501>*4
10 sheets: A4 and Letter
Photo Paper Glossy <GP-502>*4
Photo Paper Plus Glossy II <PP-201>*4
10 sheets: 5" x 7" (13 x 18 cm)
Photo Paper Pro Luster <LU-101>*4
N/A*2
Photo Paper Plus Semi-gloss <SG-201>*4
Matte Photo Paper <MP-101>
Paper for printing business documents:
Cassette (upper)
Cassette (lower)
Paper Output Tray
N/A*2
65 sheets
50 sheets
Paper for creating your own prints:
Cassette (upper)
Cassette (lower)
T-Shirt Transfers <TR-301>
N/A*2
1 sheet
Photo Stickers <PS-101>
1 sheet
N/A*5
*1 Proper feeding of paper may not be possible at the maximum capacity depending on the type of paper or environmental conditions (either very high or low temperature or humidity). In such cases, reduce the number of paper you load at a time to less than half.
*2 Feeding paper from the cassette (upper) can damage the printer. Always load in the cassette (lower).
*3 We recommend that you remove the previously printed envelope from the paper output tray before continuously printing to avoid blurs and discoloration.
*4 When loading paper in stacks, the print side may become marked as it is fed or paper may not feed properly. In this case, load one sheet at a time.
*5 Feeding paper from the cassette (lower) can damage the printer. Always load in the cassette (upper).
Powered by
