Salesforce
How to Access or Change Machine Settings - TS8120
« Go Back
Information
TitleHow to Access or Change Machine Settings - TS8120
URL NameART169746
Description
Use Machine's Operation Panel to Access / View / Change settings
Solution
Machine Settings Procedure
Follow the steps below to access or change machine's device settings
  1. Make sure printer is turned on.
  2. Select   Setup on the HOME screen.
  3. Select   Settings.
  4. Select   Device settings.
    The Device settings screen is displayed.
  5. Select the setting item to view or change
  6. Make desired changes .
TS8120 Page
Powered by
