Salesforce
How to initiate Cableless setup - MB2720
« Go Back
Information
TitleHow to initiate Cableless setup - MB2720
URL NameART170860
Description
Cableless Setup
Solution
Setting up the MAXIFY Printer for use on a Wireless LAN
The Cableless setup method is a quick and easy way to set up the printer for use on a Wi-Fi (Wireless) network. Follow the instructions below to set  the printer into cableless setup mode.
Start Cableless Setup on the printer.
  1. Press the HOME button (A) on the printer.
    If an error screen is displayed, tap OK, then press the HOME button.
    HOME screen
  2. Flick the screen left or right, then tap LAN settings.
    HOME screen: Select LAN settings
  3. Tap Wireless LAN setup.
    LAN settings screen: Select Wireless LAN setup
  4. Tap Cableless setup.
    Wireless LAN setup screen: Select Cableless setup
  5. Tap OK.
    Cableless setup screen: Enable direct communication with a computer or smartphone, etc., to retrieve the setting details and set up.  arrow  Cableless setup screen: Follow the instructions on the computer or smartphone, etc. to perform the operation.
  6. The printer is now ready for setup on your computer or mobile device.  Follow any instructions.
    Mac ComputersWindows ComputersAndroid DevicesiOS Devices
MB2720 Page
Powered by
