To use the PIXMA TS6220 wirelessly, you need to connect the printer to your Wi-Fi® Network, then the download and install the printer software on your Mac®.
Follow the instructions below to use the Easy Wireless Connect method to connect your printer to a wireless network.
There are two parts to the setup process:
- Start Easy Wireless Connect on the printer.
- Download and run the setup file on your computer.
1. Start Easy Wireless Connect on the printer
Turn the printer ON. (If the power is on, the POWER lamp (A) is lit.)
If the printer is busy with a cleaning, print head alignment or other task, wait for it to finish.
Press the HOME
button on the printer. If an error screen displays, tap OK, then press the HOME
button.
Tap the Wireless connect
(A) icon.
Tap Yes.
The screen below appears. It may take time until the printer is detected and the screen changes.
2. Download and run the setup file on your computer
Download the setup file.
Read the information taking note of any warning messages that appear during setup, then select Download.
If you see a message like this:
Select OK. Then, control-click on the setup file, select Open, then select Open in the error message window. This will allow the setup program to proceed.
Select Next on the first screen.
Enter your computer User Name and Password, then select Install Helper.
Select Start Setup.
Read the network security notice, then select Next.
Select the appropriate region from the drop-down, then select Next.
Read the License Agreement, then select Yes to continue.
Select Agree or Do Not Agree to the information request.
Select Yes to confirm the connection method.
Setup continues. Please wait.
If the following appears, select Allow.
Network connection is complete. Select Next. Setup is almost finished.
Select Add Printer.
Select the following on the Add screen:
TS series with Bonjour Multifunction listed in the Kind column.
AirPrint or Secure AirPrint in the Use: drop-down.
Add (you will return to the Helper tool).
Select Next to continue.
Select Start if you want to run a test print, or Next to continue.
On the Setup Complete screen, select Next.
Select any additional software you want to add, then select Next. If you select additional software, the installation may take several minutes to complete.
Select Next on the You Can Print... screen.
Select Skip or Register Now.
Select a desktop shortcut preference then select Next.
Select Exit. Installation is complete. You are ready to print or scan wirelessly from your Mac.
If your product issue was not resolved after following the steps above, or if you require additional help, please create or log in to your Canon Account to see your technical support options.Or if you still need help, visit our Canon Community by clicking the button below to get answers:
____________________________________________________________________________________________
