Salesforce
Paper Load Limit - TS9520 / TS9521C
« Go Back
Information
TitlePaper Load Limit - TS9520 / TS9521C
URL NameART171721
Description
Paper load limit
Solution
Genuine Canon Paper
Paper for printing documents:
Media Name <Model No.>Rear TrayCassettePaper Output Tray
Canon Red Label Superior <WOP111>Approx. 100 sheetsApprox. 100 sheetsApprox. 50 sheets
Canon Océ Office Colour Paper <SAT213>Approx. 80 sheetsApprox. 80 sheetsApprox. 50 sheets
High Resolution Paper <HR-101N>*1Approx. 80 sheets (B4: 50 sheets, A3: 20 sheets)N/AApprox. 20 sheets
Paper for printing photos:
Media Name <Model No.>Rear TrayPaper Output Tray
Photo Paper Pro Platinum <PT-101>*2
A4, Letter, A3, 8" x 10" (20 x 25 cm): 10 sheets
4" x 6" (10 x 15 cm): 20 sheets
10" x 12" (25 x 30 cm): 1 sheet
*3
Glossy Photo Paper "Everyday Use" <GP-501>*2
A4, Letter, A3: 10 sheets
*3
Photo Paper Glossy <GP-701>*2
*3
Photo Paper Plus Glossy II <PP-201/PP-301>*2
A4, Letter, A3, 5" x 7" (13 x 18 cm), 8" x 10" (20 x 25 cm): 10 sheets
4" x 6" (10 x 15 cm), Square 4" x 4" 10 x 10 cm, Square 5" x 5" 13 x 13 cm: 20 sheets
*3
Photo Paper Pro Luster <LU-101>*2A4, Letter, A3: 10 sheets*3
Photo Paper Plus Semi-gloss <SG-201>*2
*3
Matte Photo Paper <MP-101>
*3
Paper other than Genuine Canon Paper
Common NameRear TrayCassettePaper Output Tray
Plain Paper (including recycled paper)*1Approx. 100 sheets (Legal, 11" x 17" (28 x 43 cm), A3, B4: 50 sheets)Approx. 100 sheetsApprox. 50 sheets (Legal, 11" x 17" (28 x 43 cm), A3, B4: 10 sheets)
Envelopes10 envelopesN/A*3
T-Shirt TransfersA4: 1 sheetN/A*3
Greeting CardLetter, 7" x 10" (18 x 25 cm): 1 sheetN/A*3
Card StockA4, Letter, 12" x 12" (30 x 30 cm): 1 sheetN/A*3
  • *1 Normal feeding at maximum capacity may not be possible with some types of paper, or under very high or low temperature or humidity. In this case, load half the amount of paper or less.
  • *2 Feeding from a loaded stack of paper may leave marks on the printed side or prevent efficient feeding. In this case, load one sheet at a time.
  • *3 For best results in continuous printing, remove printed paper or envelopes from the paper output tray to avoid smearing or discoloration.
TS9520 / TS9521C Support Page
Powered by
