Lean how to use the Easy Wireless Connect method to connect to print and scan wirelessly.
The PIXMA TS8220 printer must be connected to the wireless network to print or scan wirelessly, and the correct drivers and software must be installed on the computer.
This article is for Mac, please click this link for instructions on wireless set up for Windows.
The setup process consists of 2 parts:
- Starting Easy Wireless Connect on the printer.
- Download and run the setup file.
1. Start Easy Wireless Connect on the printer
Tap
(A).
Tap Yes.
When the printer is ready, the screen below appears.
It may take time until the screen changes.
2. Download and run the setup file
Click the link to Get the Setup File, identify the file compatible with your computer's operating system and click the
to initiate installation. Double-click the downloaded .dmg file if the setup icon does not appear. Once you download the files you can follow the steps below to complete the setup process.
If you see a message like this:
Select OK. Then, control-click on the setup file, select Open, then select Open in the error message window. This will allow the setup program to proceed.
Click Next.
Enter the network password and click Install Helper.
Click Start Setup.
Click Next.
Select region and click Next.
Click Yes on the License Agreement.
Click Yes on the Connection Method screen.
Click Add Printer.
Select your printer series with Bonjour Multifunction listed in the Kind column and click Add.
Click Next.
Click Next.
Click Next on Setup Complete.
Select any optional software you wish to install and click Next.
Click Next.
Select to either register the printer or Skip.
Select whether or not to create a shortcut to the online manual and click Next.
Click Exit.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
____________________________________________________________________________________________
TS8220 Support Page
