You can load A4, B5, A5, or Letter-sized plain paper in the cassette.
Note
In the cassette, be sure to load only plain paper.
You can use general copy paper or Canon Red Label Superior WOP111/Canon Océ Office Colour Paper SAT213.
For the page size and paper weight you can use for this printer, see Supported Media Types.
Prepare paper.
Align the edges of paper. If paper is curled, flatten it.
Note
Align the edges of paper neatly before loading. Loading paper without aligning the edges may cause paper jams.
If paper is curled, hold the curled corners and gently bend them in the opposite direction until the paper becomes completely flat.
Pull out the cassette (A) from the printer.
Remove the cassette cover (B).
Slide paper guides (C) in front and (D) on right to open guides.
Load paper stack in portrait orientation WITH PRINT SIDE FACING DOWN, and place it in center of cassette.
Important
Note
Align the paper stack with the edge of the cassette as shown in the figure below.
If the paper stack is in contact with the protrusion (G), the paper may not be fed properly.
Slide front paper guide (C) to align it with paper stack.
Align paper guide with where it clicks into place.
Slide right paper guide (D) to align it with paper stack.
Do not slide the paper guide too hard against the paper. The paper may not be fed properly.
Note
Mount cassette cover (B) and insert cassette into printer.
Push the cassette into the printer until it stops.
Pull out the paper output tray (J) and open the paper output support (K).
Note
To prevent incorrect printing, this printer has a function that detects whether the settings for the paper loaded in the cassette matches the paper settings. Before printing, make print settings in accordance with the paper settings. When this function is enabled, an error message is displayed if these settings do not match to prevent incorrect printing. When this error message is displayed, check and correct the paper settings.
When the cassette is pulled out, it automatically extends. To shorten the extended cassette, push it in while pulling lever (L).
