To print or scan wirelessly on a Mac computer, the printer must first be connected to the wireless network and software drivers and applications installed. Please follow the instructions below.
Start Easy Wireless Connect on the printer first before you set up the computer or mobile device.
If the printer is in the process of cleaning, print head alignment, etc., wait for the process to finish before you start the setup.
Notes on Wireless Connection.
Start easy wireless connect on the printer.
Press and hold the Wireless Connect button
until Processing... appears.
Release the button.
Download and install the drivers and software.
Download the setup file.
Select the install icon
in the dock and follow the on-screen instructions to proceed with setup.
Double-click the downloaded .dmg file if setup icon did not appear.
Select Next.
Enter the network password and select Install Helper.
Select Start Setup.
Select Next.
Select Yes on the License Agreement screen.
Select Do not agree or Agree. The software will be installed regardless of your selection.
If Do not agree was selected, the information below appears. Select OK.
Select Next on the Connection Method screen.
Select Allow on the keychain message.
Based on your network setup, the screens below may appear. Be sure to select an SSID (network) in the dropdown list running on the 2.4Ghz frequency. Check your router's instruction manual if you have any questions.
After you select the SSID, enter the password in the next screen.
Select Next on the Connection completed screen.
Select Add Printer.
Select your printer series with Bonjour Multifunction listed in the Kind column and choose Add.
Select Next.
Select Next.
If you wish to download and install any additional software, Select Continue online.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
____________________________________________________________________________________________
