Tap
(A).
Tap Wi-Fi.
Tap Settings.
Tap Wi-Fi setup.
Tap Manual connect.
Tap your wireless router.
If a different screen appears or no wireless router is found, see "Troubleshooting."
One of the screens below will appear.
If "Connected to the wireless router." appears, the network does not require a password. Continue from step 8.
If a different screen appears, see "Troubleshooting."
Tap the input area.
Enter the password. Text entry is case-sensitive.
For how to enter characters and how to change the character type, see "Text Entry" (appears in a new window).
If you don't know the password for your wireless router, see the wireless router manual or contact its manufacturer.
Tap OK.
Tap OK.
When the screen on the below appears, tap OK.
Tap
on the left side of the screen.
The network connection setup is now complete.
When connection is complete,
appears at the bottom left of the screen.
Return to the software and proceed with the installation.
Windows
Click
in the taskbar, follow the on-screen instructions to proceed with setup.
macOS
Click
in the Dock, follow the on-screen instructions to proceed with setup.
