Salesforce
Initiating Easy Wireless Connect - TS3320 / TS3322
« Go Back
Information
TitleInitiating Easy Wireless Connect - TS3320 / TS3322
URL NameART175359
Description
This article explains how to initiate wireless setup on the PIXMA TS3320 / TS3322 and provides instruction for completing Easy Wireless Connect when using Android, iOS, Mac, or Windows.
Solution
Start Easy Wireless Connect on the printer.
Before connecting your printer to an Android, iOS, Mac, or Windows device, you must first initiate Easy Wireless Connect on the printer.
See the procedure below to start the Easy Wireless Connect.
  1. Press and hold the Direct button (A) on the printer, and then release the button when  Direct icon(B) flashes.
    figure: Press and hold the Direct button and the Direct icon flashes
Make sure the network icon  Network status icon and the horizontal bars (C) flash as shown in the illustration below.
figure: Network status icon and the lower two horizontal bars flash
Complete the connection with your computer or mobile device
After the printer is in Easy Wireless Connect mode, you will need to use a computer with Windows or Mac OS, or an Android or iOS mobile device to send the network information to the printer. This will establish a wireless connection between your printer and wireless network.
Click here if you are using a Windows PC.
Click here if you are using a Mac.
Click here if you are using an iOS device.
Click here if you are using an Android device.
 In order to use your printer wirelessly with a Chromebook, the printer must first be connected wirelessly via one of the above mentioned methods. After the printer's network connection has been established, it can then be paired with the Chromebook.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
Link to Canon Community Forum
____________________________________________________________________________________________
Powered by
