Salesforce
Paper Settings on the Printer Driver and the Printer (Paper Size) (Windows) - G7020
« Go Back
Information
TitlePaper Settings on the Printer Driver and the Printer (Paper Size) (Windows) - G7020
URL NameART175572
Description
This article provides information on the various paper settings available in the printer driver for the PIXMA G7020 on a Windows PC.
Solution
When you use this printer, selecting a paper size that matches the print purpose will help you achieve the best print results.
You can use the following paper sizes on this printer.
Printer Paper Size in the printer driverCassette paper information registered on the printer
Letter 8.5"x11" 22x28cm
Letter
Legal 8.5"x14" 22x36cm
Legal
A5
A5
A4
A4
B5
B5
4"x6" 10x15cm
KG/4"x6"
5"x7" 13x18cm
2L/5"x7"
7"x10" 18x25cm
7"x10"
8"x10" 20x25cm
8"x10"
L 89x127mm
L
2L 127x178mm
2L/5"x7"
Square 3.5"x3.5" 9x9cm
Square 3.5"
Square 4"x4" 10x10cm
Square 4"
Square 5"x5" 13x13cm
Square 5"
Hagaki 100x148mm
Hagaki
Hagaki 2 200x148mm
Hagaki 2
Envelope Com 10
Env. Com 10
Envelope DL
Envelope DL
Nagagata 3 4.72"x9.25"
Nagagata 3
Nagagata 4 3.54"x8.07"
Nagagata 4
Yougata 4 4.13"x9.25"
Yougata 4
Yougata 6 3.86"x7.48"
Yougata 6
Card 2.17"x3.58" 55x91mm
Card 2"x3.5"
Custom Size
Others
Powered by
