PictBridge (Wi-Fi) Print Settings
Settings on the PictBridge (Wi-Fi) Compliant Device
This part of the article describes the PictBridge (Wi-Fi) function of the printer. For the print settings on a PictBridge (Wi-Fi) compliant device, refer to the instructions given in the device's instruction manual.
Note
In the following description, names of setting items are given according to those used in Canon-brand PictBridge (Wi-Fi) compliant devices. Setting item names may be different depending on the brand or model of your device.
Some setting items explained below may not be available on some devices. In this case, the settings made on the printer are applied. Also, when some items are set to Default on a PictBridge (Wi-Fi) compliant device, the printer settings for these items are applied.
The following settings can be used when printing from a PictBridge (Wi-Fi) compliant device.
Paper size
- Letter
- A4
- 4" x 6" (10 x 15 cm)
- 5" x 7" (13 x 18 cm)
- 8" x 10" (20 x 25 cm)
- 2L (5.00 x 7.01 in. (127.0 x 178.0 mm))
- Square 3.5" x 3.5" (9 x 9 cm)
- Square 4" x 4" (10 x 10 cm)
- Square 5" x 5" (13 x 13 cm)
Note
Depending on your PictBridge (Wi-Fi) compliant device, you may not be able to select some paper sizes or paper size names may vary.
- Letter
Paper type
Default:
Glossy Photo Paper "Everyday Use" <GP-501/GP-508>
Photo Paper Glossy <GP-701>
Photo Paper Pro Luster <LU-101>
Photo Paper Plus Semi-gloss <SG-201>
Matte Photo Paper <MP-101>
Restickable Photo Paper <RP-101>
Removable Photo Stickers <PS-308R>
Magnetic Photo Paper <MG-101/PS-508>
Photo:
Photo Paper Plus Glossy II <PP-201/PP-208/PP-301>
Photo Stickers (16 stickers per sheet) <PS-108>*
Photo Stickers (Free Cutting) <PS-208>*
Photo Stickers (Variety Pack) <PS-808>*
* When printing on sticker paper, select 4"x6"/10x15cm in Paper size. Do not set Layout to Borderless.
Fast Photo:
Photo Paper Pro Platinum <PT-101>
Plain:
Canon Red Label Superior <WOP111>
Canon Océ Office Colour Paper <SAT213>
Plain Paper
When Paper type is set to Plain, borderless printing will be disabled even when Layout is set to Borderless. -
Layout
Default (Selections based on the printer setting), Index, Borderless, Bordered, N-up (2, 4, 9, 16)*1, 1-up*2, 20-up*2, 35-up*3
*1 Layout compatible with A4 or Letter-sized paper and Canon-brand sticker above.
A4/Letter: 4-up
Photo Stickers: 2-up, 4-up, 9-up, 16-up.
*2 With a Canon brand PictBridge (Wi-Fi) compliant device, selecting items with "i" mark allows you to print shooting info (Exif Data) in list format (20-up) or on the margins of the specified data (1-up). (May not be available with some Canon-brand PictBridge (Wi-Fi) compliant devices.)
*3 Printed in 35 mm Film Style Layout (Contact Printing Layout). Available only with a Canon-brand PictBridge (Wi-Fi) compliant device. (May not be available with some Canon-brand PictBridge (Wi-Fi) compliant devices.)
Print date & file no.
Default (Off: No printing), Date, File No., Both, Off
Image optimize
Default (Selections based on the printer setting), On (Auto photo fix)*1, Off, Red-Eye*2
*1 The scene or person's face of a shot photo is recognized and the most suitable correction for each photo is made automatically. It makes a darkened face by backlight brighter to print. It also analyzes a scene such as scenery, night scene, person, etc. and corrects each scene with the most suitable color, brightness, or contrasts automatically to print.
*2 Can be selected only on certain Canon-brand PictBridge (Wi-Fi) compliant devices. (May not be selected depending on the device.)
Trimming
Default (Off: No trimming), On (follow the camera's setting), Off
Settings on the Printer
You can change the PictBridge (Wi-Fi) print settings from the PictBridge settings screen. Set the print settings to Default on the PictBridge (Wi-Fi) compliant device when you want to print according to the settings on the printer.
This part of the article describes the procedure to display the PictBridge settings screen.
Check that the printer is turned on.
Press the Setup button.
The Setup menu screen is displayed.
Select Device settings and then press the OK button.
Select PictBridge settings and then press OK button.
The message Camera settings take priority will scroll across the screen. Press the OK button.
The PictBridge settings screen is displayed.
