Item Number | Item | Description | Setting |
1 | Product Information | Product information | – |
1-1 | Product Name | Product name | XXXXXXXX |
1-2 | ROM Version | ROM version | XXXXXXXX |
1-3 | Serial Number | Serial number | XXXXXXXX |
2 | Network Diagnostics | Network diagnostics | – |
2-1 | Diagnostic Result | Diagnostic result | XXXXXXXX |
2-2 | Result Codes | Result codes | XXXXXXXX |
2-3 | Result Code Details | Result code details | http://canon.com/ijnwt |
3 | Wireless LAN | Wireless LAN | Enable/Disable |
3-2 | Infrastructure | Infrastructure | Enable/Disable |
3-2-1 | Signal Strength | Signal strength | 0 to 100 [%] |
3-2-2 | Link Quality | Link quality | 0 to 100 [%] |
3-2-3 | Frequency | Frequency | XX (GHz) |
3-2-4 | MAC Address | MAC address | XX:XX:XX:XX:XX:XX |
3-2-5 | Connection | Connection status | Active/Inactive |
3-2-6 | SSID | SSID | Wireless LAN network name (SSID) |
3-2-7 | Channel | Channel | XXX (1 to 13) |
3-2-8 | Encryption | Encryption method | None/WEP/TKIP/AES |
3-2-9 | WEP Key Length | WEP key length (bits) | Inactive/128/64 |
3-2-10 | Authentication | Authentication method | None/auto/open/shared/WPA-PSK/WPA2-PSK |
3-2-11 | TCP/IPv4 | TCP/IPv4 | Enable/Disable |
3-2-12 | IP Address | IP address | XXX.XXX.XXX.XXX |
3-2-13 | Subnet Mask | Subnet mask | XXX.XXX.XXX.XXX |
3-2-14 | Default Gateway | Default gateway | XXX.XXX.XXX.XXX |
3-2-15 | TCP/IPv6 | TCP/IPv6 | Enable/Disable |
3-2-16 | Link Local Address | Link local address | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-17 | Link Local Prefix Length | Link local prefix length | XXX |
3-2-18 | Stateless Address1 | Stateless address 1 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-19 | Stateless Prefix Length1 | Stateless prefix length 1 | XXX |
3-2-20 | Stateless Address2 | Stateless address 2 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-21 | Stateless Prefix Length2 | Stateless prefix length 2 | XXX |
3-2-22 | Stateless Address3 | Stateless address 3 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-23 | Stateless Prefix Length3 | Stateless prefix length 3 | XXX |
3-2-24 | Stateless Address4 | Stateless address 4 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-25 | Stateless Prefix Length4 | Stateless prefix length 4 | XXX |
3-2-26 | Default Gateway1 | Default gateway 1 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-27 | Default Gateway2 | Default gateway 2 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-28 | Default Gateway3 | Default gateway 3 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-29 | Default Gateway4 | Default gateway 4 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-33 | IPsec | IPsec setting | Active/Inactive |
3-2-34 | Security Protocol | Security method | ESP/ESP & AH/AH/Blank (Not selected) |
3-3 | Wireless Direct | Operation mode for Wireless Direct | Enable/Disable |
3-3-1 | MAC Address | MAC address | XX:XX:XX:XX:XX:XX |
3-3-2 | Connection | Connection status | Active/Inactive |
3-3-3 | SSID | SSID | Wireless Direct network name (SSID) |
3-3-4 | Password | Password | Wireless Direct password |
3-3-5 | Channel | Channel | 3 |
3-3-6 | Encryption | Encryption method | AES |
3-3-7 | Authentication | Authentication method | WPA2-PSK |
3-3-8 | TCP/IPv4 | TCP/IPv4 | Enable/Disable |
3-3-9 | IP Address | IP address | XXX.XXX.XXX.XXX |
3-3-10 | Subnet Mask | Subnet mask | XXX.XXX.XXX.XXX |
3-3-11 | Default Gateway | Default gateway | XXX.XXX.XXX.XXX |
3-3-12 | TCP/IPv6 | TCP/IPv6 | Enable/Disable |
3-3-13 | Link Local Address | Link local address | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-3-14 | Link Local Prefix Length | Link local prefix length | XXX |
3-3-15 | IPsec | IPsec setting | Active/Inactive |
3-3-16 | Security Protocol | Security method | ESP/ESP & AH/AH/Blank (Not selected) |
4 | Wired LAN | Wired LAN | Enable/Disable |
4-1 | MAC Address | MAC address | XX:XX:XX:XX:XX:XX |
4-2 | Connection | Wired LAN status | Active/Inactive |
4-3 | TCP/IPv4 | TCP/IPv4 | Enable/Disable |
4-4 | IP Address | IP address | XXX.XXX.XXX.XXX |
4-5 | Subnet Mask | Subnet mask | XXX.XXX.XXX.XXX |
4-6 | Default Gateway | Default gateway | XXX.XXX.XXX.XXX |
4-7 | TCP/IPv6 | TCP/IPv6 | Enable/Disable |
4-8 | Link Local Address | Link local address | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
4-9 | Link Local Prefix Length | Link local prefix length | XXX |
4-10 | Stateless Address1 | Stateless address 1 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
4-11 | Stateless Prefix Length1 | Stateless prefix length 1 | XXX |
4-12 | Stateless Address2 | Stateless address 2 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
4-13 | Stateless Prefix Length2 | Stateless prefix length 2 | XXX |
4-14 | Stateless Address3 | Stateless address 3 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
4-15 | Stateless Prefix Length3 | Stateless prefix length 3 | XXX |
4-16 | Stateless Address4 | Stateless address 4 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
4-17 | Stateless Prefix Length4 | Stateless prefix length 4 | XXX |
4-18 | Default Gateway1 | Default gateway 1 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
4-19 | Default Gateway2 | Default gateway 2 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
4-20 | Default Gateway3 | Default gateway 3 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
4-21 | Default Gateway4 | Default gateway 4 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
4-25 | IPsec | IPsec setting | Active/Inactive |
4-26 | Security Protocol | Security method | ESP/ESP & AH/AH/Blank (Not selected) |
4-27 | Wired LAN DRX | Discontinuous reception (wired LAN) | Enable/Disable |
5 | Other Settings | Other settings | – |
5-1 | Printer Name | Printer name | Printer name (Up to 15 alphanumeric characters) |
5-2 | Wireless Direct DevName | Device name for wireless direct | Device name for wireless direct (Up to 32 alphanumeric characters) |
5-4 | WSD Printing | WSD printing setting | Enable/Disable |
5-5 | WSD Timeout | Timeout | 1/5/10/15/20 [min] |
5-6 | LPD Printing | LPD printing setting | Enable/Disable |
5-7 | RAW Printing | RAW printing setting | Enable/Disable |
5-9 | Bonjour | Bonjour setting | Enable/Disable |
5-10 | Bonjour Service Name | Bonjour service name | Bonjour service name (Up to 52 alphanumeric characters) |
5-11 | LLMNR | LLMNR setting | Enable/Disable |
5-12 | SNMP | SNMP setting | Enable/Disable |
5-13 | PictBridge Commun. | PictBridge Communication | Enable/Disable |
5-14 | DNS Server | Obtain DNS server address automatically | Auto/Manual |
5-15 | Primary Server | Primary server address | XXX.XXX.XXX.XXX |
5-16 | Secondary Server | Secondary server address | XXX.XXX.XXX.XXX |
5-17 | Proxy Server | Proxy server setting | Enable/Disable |
5-18 | Proxy Address | Proxy address | XXXXXXXXXXXXXXXXXXXX |
5-19 | Proxy Port | Proxy port specification | 1 to 65535 |
5-20 | Cert. Fingerprt(SHA-1) | Certificate fingerprint(SHA-1) | xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx |
5-21 | Cert. Fingerprt(SHA-256) | Certificate fingerprint(SHA-256) | xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx |
6 | Bluetooth | Bluetooth settings | – |
6-1 | Bluetooth Setting | Bluetooth | Enable/Disable |
6-3 | Bluetooth Device Address | Bluetooth device address of the printer | XX:XX:XX:XX:XX:XX |
6-5 | Bluetooth Device Name | Bluetooth device name of the printer | XXXXXXXX |
7 | Web Services | Web Services | – |
7-1 | Unsent Usage Logs | Number of unsent usage logs | 0 to 200 |
7-2 | Usage Log Last Sent | Last date when usage log was sent | XXXXXXXX |
7-3 | Web Service Status | Registration status | Not set/Disabled/Registration pending/Registered |
7-4 | Log Transmission Status | Transmission result | Not activated/Processing/Server error/Connection error/Timeout error/Error/Awaiting server response/Active |
