Printing Network Settings
Use the operation panel to print the printer's current network settings.
The network settings printout contains important information about your network. Handle it with care.
Check that printer is turned on.
Load three sheets of A4 or Letter-sized plain paper in the cassette or the rear tray.
Press the OK button on the HOME screen.
Select Device settings and press the OK button.
Select LAN settings and press OK button.
Select Print details and press the OK button.
Select Yes and press the OK button.
Check the displayed message and press the OK button.
When the confirmation screen for printing passwords appears, select ON or OFF and press the OK button.
The printer starts printing the network setting information.
The following information on the printer's network setting is printed out. (Some setting values are not displayed depending on the printer settings.)
Item Number | Item | Description | Setting |
1 | Product Information | Product information | – |
1-1 | Product Name | Product name | XXXXXXXX |
1-2 | ROM Version | ROM version | XXXXXXXX |
1-3 | Serial Number | Serial number | XXXXXXXX |
2 | Network Diagnostics | Network diagnostics | – |
2-1 | Diagnostic Result | Diagnostic result | XXXXXXXX |
2-2 | Result Codes | Result codes | XXXXXXXX |
2-3 | Result Code Details | Result code details | http://canon.com/ijnwt |
3 | Wireless LAN | Wireless LAN | Enable/Disable |
3-2 | Infrastructure | Infrastructure | Enable/Disable |
3-2-1 | Signal Strength | Signal strength | 0 to 100 [%] |
3-2-2 | Link Quality | Link quality | 0 to 100 [%] |
3-2-3 | Frequency | Frequency | XX (GHz) |
3-2-4 | MAC Address | MAC address | XX:XX:XX:XX:XX:XX |
3-2-5 | Connection | Connection status | Active/Inactive |
3-2-6 | SSID | SSID | Wireless LAN network name (SSID) |
3-2-7 | Channel | Channel | XX (1 to 13) |
3-2-8 | Encryption | Encryption method | None/WEP/TKIP/AES |
3-2-9 | WEP Key Length | WEP key length (bits) | Inactive/128/64 |
3-2-10 | Authentication | Authentication method | None/auto/open/shared/WPA-PSK/WPA2-PSK |
3-2-11 | TCP/IPv4 | TCP/IPv4 | Enable/Disable |
3-2-12 | IP Address | IP address | XXX.XXX.XXX.XXX |
3-2-13 | Subnet Mask | Subnet mask | XXX.XXX.XXX.XXX |
3-2-14 | Default Gateway | Default gateway | XXX.XXX.XXX.XXX |
3-2-15 | TCP/IPv6 | TCP/IPv6 | Enable/Disable |
3-2-16 | Link Local Address | Link local address | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-17 | Link Local Prefix Length | Link local prefix length | XXX |
3-2-18 | Stateless Address1 | Stateless address 1 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-19 | Stateless Prefix Length1 | Stateless prefix length 1 | XXX |
3-2-20 | Stateless Address2 | Stateless address 2 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-21 | Stateless Prefix Length2 | Stateless prefix length 2 | XXX |
3-2-22 | Stateless Address3 | Stateless address 3 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-23 | Stateless Prefix Length3 | Stateless prefix length 3 | XXX |
3-2-24 | Stateless Address4 | Stateless address 4 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-25 | Stateless Prefix Length4 | Stateless prefix length 4 | XXX |
3-2-26 | Default Gateway1 | Default gateway 1 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-27 | Default Gateway2 | Default gateway 2 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-28 | Default Gateway3 | Default gateway 3 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-29 | Default Gateway4 | Default gateway 4 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-33 | IPsec | IPsec setting | Active/Inactive |
3-2-34 | Security Protocol | Security method | ESP/ESP & AH/AH/Blank (Not selected) |
3-3 | Wireless Direct | Operation mode for Wireless Direct | Enable/Disable |
3-3-1 | MAC Address | MAC address | XX:XX:XX:XX:XX:XX |
3-3-2 | Connection | Connection status | Active/Inactive |
3-3-3 | SSID | SSID | Wireless Direct network name (SSID) |
3-3-4 | Password | Password | Wireless Direct password |
3-3-5 | Channel | Channel | 3 |
3-3-6 | Encryption | Encryption method | AES |
3-3-7 | Authentication | Authentication method | WPA2-PSK |
3-3-8 | TCP/IPv4 | TCP/IPv4 | Enable/Disable |
3-3-9 | IP Address | IP address | XXX.XXX.XXX.XXX |
3-3-10 | Subnet Mask | Subnet mask | XXX.XXX.XXX.XXX |
3-3-11 | Default Gateway | Default gateway | XXX.XXX.XXX.XXX |
3-3-12 | TCP/IPv6 | TCP/IPv6 | Enable/Disable |
3-3-13 | Link Local Address | Link local address | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-3-14 | Link Local Prefix Length | Link local prefix length | XXX |
3-3-15 | IPsec | IPsec setting | Active/Inactive |
3-3-16 | Security Protocol | Security method | ESP/ESP & AH/AH/Blank (Not selected) |
5 | Other Settings | Other settings | – |
5-1 | Printer Name | Printer name | Printer name (Up to 15 alphanumeric characters) |
5-2 | Wireless Direct DevName | Device name for wireless direct | Device name for wireless direct (Up to 32 alphanumeric characters) |
5-4 | WSD Printing | WSD printing setting | Enable/Disable |
5-5 | WSD Timeout | Timeout | 1/5/10/15/20 [min] |
5-6 | LPD Printing | LPD printing setting | Enable/Disable |
5-7 | RAW Printing | RAW printing setting | Enable/Disable |
5-9 | Bonjour | Bonjour setting | Enable/Disable |
5-10 | Bonjour Service Name | Bonjour service name | Bonjour service name (Up to 52 alphanumeric characters) |
5-11 | LLMNR | LLMNR setting | Enable/Disable |
5-12 | SNMP | SNMP setting | Enable/Disable |
5-13 | PictBridge Commun. | PictBridge Communication | Enable/Disable |
5-14 | DNS Server | Obtain DNS server address automatically | Auto/Manual |
5-15 | Primary Server | Primary server address | XXX.XXX.XXX.XXX |
5-16 | Secondary Server | Secondary server address | XXX.XXX.XXX.XXX |
5-17 | Proxy Server | Proxy server setting | Enable/Disable |
5-18 | Proxy Address | Proxy address | XXXXXXXXXXXXXXXXXXXX |
5-19 | Proxy Port | Proxy port specification | 1 to 65535 |
5-20 | Cert. Fingerprt(SHA-1) | Certificate fingerprint(SHA-1) | xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx |
5-21 | Cert. Fingerprt(SHA-256) | Certificate fingerprint(SHA-256) | xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx |
6 | Bluetooth | Bluetooth settings | – |
6-1 | Bluetooth Setting | Bluetooth | Enable/Disable |
6-3 | Bluetooth Device Address | Bluetooth device address of the printer | XX:XX:XX:XX:XX:XX |
6-5 | Bluetooth Device Name | Bluetooth device name of the printer | XXXXXXXX |
7 | Web Services | Web Services | – |
7-1 | Unsent Usage Logs | Number of unsent usage logs | 0 to 200 |
7-2 | Usage Log Last Sent | Last date when usage log was sent | XXXXXXXX |
7-3 | Web Service Status | Registration status | Not set/Disabled/Registration pending/Registered |
7-4 | Log Transmission Status | Transmission result | Not activated/Processing/Server error/Connection error/Timeout error/Error/Awaiting server response/Active |
7-5 | Subscription Information | Subscription Information | Subscription agreement information (Printed with or without subscription agreement) |
7-5-1 | Subscription Ink |
7-5-2 | Remaining Offline Prints |
7-5-3 | Installed Cartridge Type |
7-5-4 | Online Support | Support page URL for subscription contractors only (If mentioned) | If you have a subscription contract, please check the contractor-only support page. |
("XX" represents alphanumeric characters.)
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
____________________________________________________________________________________________
