Salesforce
Paper Settings on the Printer Driver and the Printer (Paper Size) (Windows) - PRO-200
« Go Back
Information
TitlePaper Settings on the Printer Driver and the Printer (Paper Size) (Windows) - PRO-200
URL NameART177830
Description
Learn about the paper sizes found in the Windows printer driver for the PIXMA PRO-200 and how they compare to the sizes found on the operation panel.
Solution
When you use this printer, selecting a paper size that matches the print purpose will help you achieve the best print results.
You can use the following paper sizes on this printer.
Printer Paper Size in the printer driver
Paper information registered on the printer
Letter 8.5"x11" 22x28cm
Letter
Legal 8.5"x14" 22x36cm
Legal
11"x17" 279.4x431.8mm
11"x17"(28x43cm)
A5
A5
A4
A4
A3
A3
A3+ 13"x19" 33x48cm
A3+
B5
B5
B4
B4
4"x6" 10x15cm
KG/4"x6"(10x15)
5"x7" 13x18cm
2L/5"x7"(13x18)
7"x10" 18x25cm
7"x10"(18x25cm)
8"x10" 20x25cm
8"x10"(20x25cm)
10"x12" 25x30cm
10"x12"(25x30cm)
210x594mm
210x594mm
L 89x127mm
L(89x127mm)
2L 127x178mm
2L/5"x7"(13x18)
Square 5"x5" 13x13cm
Square 5"
Square 12"x12" 30x30cm
12"x12"(30x30cm)
Letter (Margin 25)
Letter
11"x17" (Margin 25)
11"x17"(28x43cm)
A4 (Margin 25)
A4
A3 (Margin 25)
A3
A3+ (Margin 25)
A3+
210x594mm (Margin 25)
210x594mm
Hagaki 100x148mm
Hagaki
Hagaki 2 200x148mm
Hagaki 2
Envelope Com 10
Envelope Com 10
Envelope DL
Envelope DL
Nagagata 3 4.72"x9.25"
Nagagata 3
Nagagata 4 3.54"x8.07"
Nagagata 4
Yougata 4 4.13"x9.25"
Yougata 4
Yougata 6 3.86"x7.48"
Yougata 6
Custom Size
Others
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
Link to Canon Community Forum
____________________________________________________________________________________________
Powered by
