Salesforce
Before Printing on Art Paper - PRO-200
« Go Back
Information
TitleBefore Printing on Art Paper - PRO-200
URL NameART177833
Description
This article provides information you'll need to know before using art paper with the PIXMA PRO-200.
Solution
When using art paper, dust is liable to be generated. It is therefore recommended that paper dust be removed on art paper just before printing.
You will need a soft hair brush (or similar brush used to clean office automation equipment).
The wider the brush, the more effective it will be.
Figure: Brushes
OK - soft brush made from material such as polypropylene, polyethylene, horse hair or goat hair.
 Be sure not to use brushes as shown below. The printing surface may be damaged.
Figure: Don't use brushes like these
Not OK - brush made from hard material, cloth or washcloth, sticky and abrasive materials.
Paper dust removal procedure:
  1. Check that the brush is not wet and free from dust or dirt.
  2. Brush the overall printing surface carefully in one direction.
    Figure: Brush the printing surface horizontally in one direction
     Be sure to brush all the way across the paper; don't start brushing at the middle or stop halfway.
     Try to avoid touching the printing surface as much as possible.
  3. To complete the removal of paper dust, brush the paper in the other direction from top to bottom.
    Figure: Brush from the top of the paper to the bottom
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
Link to Canon Community Forum
____________________________________________________________________________________________
Powered by
