PictBridge (Wi-Fi) Print Settings
Settings on PictBridge (Wi-Fi) Compliant Device
This article describes the PictBridge (Wi-Fi) function of the printer. For the print settings on a PictBridge (Wi-Fi) compliant device, refer to the instructions given in the device's instruction manual.
In the following description, names of setting items are given according to those used in Canon-brand PictBridge (Wi-Fi) compliant devices. Setting item names may be different depending on the brand or model of your device.
Some setting items explained below may not be available on some devices. In this case, the settings made on the printer are applied. Also, when some items are set to Default on a PictBridge (Wi-Fi) compliant device, the printer settings for these items are applied.
The following settings can be used when printing from a PictBridge (Wi-Fi) compliant device.
Layout
Default (Selections based on the printer setting), Borderless, Bordered, 1-up*1, 20-up*2, 35-up*3
*1, *2 With a Canon brand PictBridge (Wi-Fi) compliant device, selecting items with "i" mark allows you to print shooting info (Exif Data) in list format (20-up) or on the margins of the specified data (1-up). (May not be available with some Canon-brand PictBridge (Wi-Fi) compliant devices.)
*3 Printed in 35 mm Film Style Layout (Contact Printing Layout). Available only with a Canon-brand PictBridge (Wi-Fi) compliant device. (May not be available with some Canon-brand PictBridge (Wi-Fi) compliant devices.)
Print date & file no.
Default (Off: No printing), Date, File No., Both, Off
Image optimize
Default (Selections based on the printer setting), On (Auto photo fix)*1, Off, Red-Eye*2
*1 The scene or person's face of a shot photo is recognized and the most suitable correction for each photo is made automatically. It makes a darkened face by backlight brighter to print. It also analyzes a scene such as scenery, night scene, person, etc. and corrects each scene with the most suitable color, brightness, or contrasts automatically to print.
*2 Can be selected only on certain Canon-brand PictBridge (Wi-Fi) compliant devices. (May not be selected depending on the device.)
Settings on Printer
You can change the PictBridge (Wi-Fi) print settings from the PictBridge print settings screen. Set the print settings to Default on the PictBridge (Wi-Fi) compliant device when you want to print according to the settings on the printer.
Follow the procedure below to display the PictBridge print settings screen.
Make sure that the printer is powered on
Select
Various settings on the HOME screen and press the OK button.
Use the
buttons to select Printer settings, and press the OK button.
Use the
buttons to select PictBridge print settings, and press the OK button.
Check the message that is displayed and press the OK button.
The PictBridge print settings screen is displayed.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
____________________________________________________________________________________________
