Salesforce
MAXIFY GX7020 Easy Wireless Connect Setup - Windows
« Go Back
Information
TitleMAXIFY GX7020 Easy Wireless Connect Setup - Windows
URL NameART179740
Description
Use Easy wireless connect to establish the printer's wireless connection to your network.
Solution
Wireless Setup - Windows** Computers
**Instructions in this article are for setup on a Windows computer.  If setting up on a Mac, click here for instructions
To be able to use your printer to print or scan wirelessly on a Windows computer, the printer must first be connected to the wireless network. Then, drivers and software need to be installed on the computer. The instructions / screenshots below show the setup program steps when using the Easy wireless connect method to connect to the wireless network.
The setup process consists of 2 parts:
  1. Starting Easy wireless connect on the printer, and
  2. Downloading and running the setup file to install the drivers and software.
Start Easy wireless connect on the printer
Prior to starting setup on the computer, start Easy wireless connect on the printer. Then complete the setup on the computer.
See the procedure below to start Easy wireless connect.
  1. Tap and hold the   Wireless connect symbol until the following appears on the touch screen.
    Figure: LCD
Download and run the setup file.*
Get the Setup File
  1. Run the setup file and click Start Setup.
    Click Start Setup (outlined in red) to proceed
  1. Read the network security notice and click Next.
    Click Next (outlined in red) to proceed
    The installer will acquire information on the latest driver and software for the printer. This may take several minutes.
    Acquiring information on the latest driver and software
  2. Read the license agreement. Select Yes to proceed.  If you click No, the installation will not proceed.
    Click Yes (outlined in red) to proceed
  3. Select Agree or Do Not Agree to the information request.
    Click Agree or Do not agree (both outlined in red) to proceed
  4. This message appears if you selected Do not agree. Click OK to proceed.
    Click OK (outlined in red) to proceed
  5. Select Yes to confirm the connection method.
  6. Depending on your network setup, the following screens may appear.  Be sure to select an SSID (network) in the dropdown list running on the 2.4Ghz frequency. If not sure, check with your router's documentation.  After selecting the SSID, enter the password in the next screen
  7. When the connection is completed, click Next.
     If your printer is not detected, make sure that the computer has reconnected to the correct network. Also, you may need to temporarily disable any firewall software, or you may need to open blocked ports in the firewall. If your PC is connected to a VPN (Virtual Private Network), temporarily disconnect from the VPN and try the setup again. Also, if you are using a dual-band router, further troubleshooting information can be found here.
  8. The MP Drivers will be downloaded and installed. This may take several minutes.
  9. Click Next.
  10. Click Continue online. The installer will close.
    Click Continue online (outlined in red) to close the installer
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
Link to Canon Community Forum
____________________________________________________________________________________________
Powered by
