Salesforce
Feed Settings - G3270
« Go Back
Information
TitleFeed Settings - G3270
URL NameART181457
Description
Learn about the paper feed settings that can be adjusted on the PIXMA G3270.
Solution
Select this setting item from Settings on the printer's LCD.
 By registering the paper size and the media type, a message can be displayed before printing starts when the paper size or the media type of the loaded paper differs from the paper settings.
  • Rear tray paper settings
    Registers the paper size and the media type you load on the rear tray.
  • Check paper replacement
    If you select Enable, the printer detects the paper replacement. A screen for confirming the setting of paper is displayed.
    Figure: LCD
     A screen for confirming the setting of paper is not displayed if you select Disable. Set the size and type of paper properly in Rear tray paper settings when making prints.
     For AirPrint in iOS iPadOS, paper may be printed based on the paper size set during paper loading. It is recommended to set to Enable when making prints using an AirPrint function.
  • Detect paper setting mismatch
    If you select Enable, the printer detects whether the paper size and the media type are identical with those registered in Feed settings. If printing starts with the settings that do not match, an error message is displayed on the LCD.
     When Disable is selected, the settings in Feed settings are disabled.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
Link to Canon Community Forum
____________________________________________________________________________________________
Powered by
