Item Number | Item | Description | Setting |
1 | Product Information | Product information | – |
1-1 | Product Name | Product name | XXXXXXXX |
1-2 | ROM Version | ROM version | XXXXXXXX |
1-3 | Serial Number | Serial number | XXXXXXXX |
1-4 | Default Password | Default password (for accessing Remote UI) | XXXXXXXX |
2 | Network Diagnostics | Network diagnostics | – |
2-1 | Diagnostic Result | Diagnostic result | XXXXXXXX |
2-2 | Result Codes | Result codes | XXXXXXXX |
2-3 | Result Code Details | Result code details | Information on the codes in this section can be found here. |
3 | Wireless LAN | Wireless LAN | Enable / Disable |
3-2 | Infrastructure | Infrastructure | Enable / Disable |
3-2-1 | Signal Strength | Signal strength | 0 to 100 [%] |
3-2-2 | Link Quality | Link quality | 0 to 100 [%] |
3-2-3 | Frequency | Frequency | 2.4 / 5 [GHz] |
3-2-4 | MAC Address | MAC address | XX:XX:XX:XX:XX:XX |
3-2-5 | Connection | Connection status | Active / Inactive |
3-2-6 | SSID | SSID | Wireless LAN network name (SSID) |
3-2-7 | Channel | Channel | XXX (1 to 13, 36, 40, 44, 48, 52, 56, 60, 64, 100, 104, 108, 112, 116, 120, 124, 128, 132, 136, 140, 149, 153, 157, 161, 165) |
3-2-8 | Encryption | Encryption method | none / TKIP / AES |
3-2-10 | Authentication | Authentication method | none / auto / open / shared / WPA-PSK / WPA2-PSK / WPA3-SAE / WPA-EAP / WPA2-EAP / WPA3-EAP |
3-2-11 | TCP / IPv4 | TCP / IPv4 | Enable |
3-2-12 | IP Address | IP address | XXX.XXX.XXX.XXX |
3-2-13 | Subnet Mask | Subnet mask | XXX.XXX.XXX.XXX |
3-2-14 | Default Gateway | Default gateway | XXX.XXX.XXX.XXX |
3-2-15 | TCP / IPv6 | TCP / IPv6 | Enable / Disable |
3-2-16 | Link Local Address | Link local address | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-17 | Link Local Prefix Length | Link local prefix length | XXX |
3-2-18 | Stateless Address1 | Stateless address 1 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-19 | Stateless Prefix Length1 | Stateless prefix length 1 | XXX |
3-2-20 | Stateless Address2 | Stateless address 2 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-21 | Stateless Prefix Length2 | Stateless prefix length 2 | XXX |
3-2-22 | Stateless Address3 | Stateless address 3 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-23 | Stateless Prefix Length3 | Stateless prefix length 3 | XXX |
3-2-24 | Stateless Address4 | Stateless address 4 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-25 | Stateless Prefix Length4 | Stateless prefix length 4 | XXX |
3-2-26 | Default Gateway1 | Default gateway 1 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-27 | Default Gateway2 | Default gateway 2 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-28 | Default Gateway3 | Default gateway 3 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-29 | Default Gateway4 | Default gateway 4 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-2-33 | IPsec | IPsec setting | Active / Inactive |
3-2-34 | Security Protocol | Security method | ESP / ESP & AH / AH / Blank (Not selected) |
3-2-35 | Wireless LAN DRX | Discontinuous reception (wireless LAN) | Enable / Disable |
3-3 | Wireless Direct / Access Point Mode | Operation mode for Wireless Direct | Enable / Disable |
3-3-1 | MAC Address | MAC address | XX:XX:XX:XX:XX:XX |
3-3-2 | Connection | Connection status | Active / Inactive |
3-3-3 | SSID | SSID | Wireless Direct network name (SSID) |
3-3-4 | Password | Password | Wireless Direct password |
3-3-5 | Channel | Channel | 3,6,36,40 |
3-3-6 | Encryption | Encryption method | AES |
3-3-7 | Authentication | Authentication method | WPA2-PSK |
3-3-8 | TCP / IPv4 | TCP / IPv4 | Enable |
3-3-9 | IP Address | IP address | XXX.XXX.XXX.XXX |
3-3-10 | Subnet Mask | Subnet mask | XXX.XXX.XXX.XXX |
3-3-11 | Default Gateway | Default gateway | XXX.XXX.XXX.XXX |
3-3-12 | TCP / IPv6 | TCP / IPv6 | Enable / Disable |
3-3-13 | Link Local Address | Link local address | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
3-3-14 | Link Local Prefix Length | Link local prefix length | XXX |
3-3-15 | IPsec | IPsec setting | Active / Inactive |
3-3-16 | Security Protocol | Security method | ESP / ESP & AH / AH / Blank (Not selected) |
3-3-17 | Wireless LAN DRX | Discontinuous reception (wireless direct) | Disable |
3-3-18 | Frequency | Wireless Direct frequency | 2.4 / 5 [GHz] |
4 | Wired LAN | Wired LAN | Enable / Disable |
4-1 | MAC Address | MAC address | XX:XX:XX:XX:XX:XX |
4-2 | Connection | Wired LAN status | Active / Inactive |
4-3 | TCP / IPv4 | TCP / IPv4 | Enable |
4-4 | IP Address | IP address | XXX.XXX.XXX.XXX |
4-5 | Subnet Mask | Subnet mask | XXX.XXX.XXX.XXX |
4-6 | Default Gateway | Default gateway | XXX.XXX.XXX.XXX |
4-7 | TCP / IPv6 | TCP / IPv6 | Enable / Disable |
4-8 | Link Local Address | Link local address | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
4-9 | Link Local Prefix Length | Link local prefix length | XXX |
4-10 | Stateless Address1 | Stateless address 1 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
4-11 | Stateless Prefix Length1 | Stateless prefix length 1 | XXX |
4-12 | Stateless Address2 | Stateless address 2 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
4-13 | Stateless Prefix Length2 | Stateless prefix length 2 | XXX |
4-14 | Stateless Address3 | Stateless address 3 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
4-15 | Stateless Prefix Length3 | Stateless prefix length 3 | XXX |
4-16 | Stateless Address4 | Stateless address 4 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
4-17 | Stateless Prefix Length4 | Stateless prefix length 4 | XXX |
4-18 | Default Gateway1 | Default gateway 1 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
4-19 | Default Gateway2 | Default gateway 2 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
4-20 | Default Gateway3 | Default gateway 3 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
4-21 | Default Gateway4 | Default gateway 4 | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
4-25 | IPsec | IPsec setting | Active / Inactive |
4-26 | Security Protocol | Security method | ESP / ESP & AH / AH / Blank (Not selected) |
4-27 | Wired LAN DRX | Discontinuous reception (wired LAN) | Enable / Disable |
5 | Other Settings | Other settings | – |
5-1 | Printer Name | Printer name | Printer name |
5-2 | Wireless Direct DevName | Device name for wireless direct | Device name for wireless direct |
5-4 | WSD Printing | WSD printing setting | Enable / Disable |
5-5 | WSD Timeout | Timeout | 1 / 5 / 10 / 15 / 20 [min] |
5-6 | LPD Printing | LPD printing setting | Enable / Disable |
5-7 | RAW Printing | RAW printing setting | Enable / Disable |
5-9 | Bonjour | Bonjour setting | Enable / Disable |
5-10 | Bonjour Service Name | Bonjour service name | Bonjour service name |
5-11 | LLMNR | LLMNR setting | Enable / Disable |
5-12 | SNMP | SNMP setting | Enable / Disable |
5-14 | DNS Server | Obtain DNS server address automatically | Auto / Manual |
5-15 | Primary Server | Primary server address | XXX.XXX.XXX.XXX |
5-16 | Secondary Server | Secondary server address | XXX.XXX.XXX.XXX |
5-17 | Proxy Server | Proxy server setting | Enable / Disable |
5-18 | Proxy Address | Proxy address | XXXXXXXXXXXXXXXXXXXX |
5-19 | Proxy Port | Proxy port specification | 1 to 65535 |
5-20 | Cert. Fingerprt(SHA-1) | Certificate fingerprint(SHA-1) | xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx |
5-21 | Cert. Fingerprt(SHA-256) | Certificate fingerprint(SHA-256) | xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx |
7 | Web Services | Web Services | – |
7-1 | Unsent Usage Logs | Number of unsent usage logs | 0 to 200 |
7-2 | Usage Log Last Sent | Last date when usage log was sent | XXXXXXXX |
7-3 | Web Service Status | Registration status | Not set / Disabled / Registration pending / Registered |
7-4 | Log Transmission Status | Transmission result | Not activated / Processing / Server error / Connection error / Timeout error / Error / Awaiting server response / Active |
9 | Security policy | Security policy status | – |
9-1 | Security administrator password | Security administrator password | Enable / Disable |
9-2 | Interface | Interface function | – |
9-2-1 | Wi-Fi policy | Wireless connection policy | – |
| Prohibit use of direct connection | Prohibit use of direct connection | Enable / Disable |
| Prohibit use of wireless LAN (Wi-Fi) | Prohibit use of wireless LAN | Enable / Disable |
9-2-2 | USB policy | USB connection policy | – |
| Prohibit use of USB connection | Prohibit use of USB device | Enable / Disable |
| Prohibit use of external USB devices | Prohibit use as USB storage device | Enable / Disable |
9-3 | Network | Network function | – |
9-3-1 | Communication policy | Communication operational policy | – |
| Always verify signatures for SMB / WebDAV server functions | Always verify signatures when using SMB / WebDAV server functions | Enable / Disable |
| Always verify server certificate when using TLS | Always verify server certificate when using TLS | Enable / Disable |
| Prohibit cleartext authentication for server functions | Prohibit cleartext authentication for server functions | Enable / Disable |
| Prohibit use of SNMPv1 | Prohibit use of SNMPv1 | Enable / Disable |
9-3-2 | Port usage policy | Port Usage Policy | – |
| Restrict LPD port | Restrict LPD port | Enable / Disable |
| Restrict RAW port | Restrict RAW port | Enable / Disable |
| Restrict FTP port | Restrict FTP port | Enable / Disable |
| Restrict WSD port | Restrict WSD port | Enable / Disable |
| Restrict BMLinkS port | Restrict BMLinkS port | Enable / Disable |
| Restrict IPP port | Restrict IPP port | Enable / Disable |
| Restrict SMB port | Restrict SMB port | Enable / Disable |
| Restrict SMTP port | Restrict SMTP port | Enable / Disable |
| Restrict dedicated port | Restrict dedicated port | Enable / Disable |
| Restrict remote operation's software port | Restrict remote operation's software port | Enable / Disable |
| Restrict SIP (IP Fax) port | Restrict SIP (IP Fax) port | Enable / Disable |
| Restrict mDNS port | Restrict mDNS port | Enable / Disable |
| Restrict SLP port | Restrict SLP port | Enable / Disable |
| Restrict SNMP port | Restrict SNMP port | Enable / Disable |
9-4 | Authentication | Authentication function | – |
9-4-1 | Authentication policy | Authentication operational policy | – |
| Prohibit guest users from using the printer | Prohibit guest users from using the device | Enable / Disable |
| Force auto logout | Force auto logout | Enable / Disable |
| Logout period | Time Until Logout | xx sec |
9-4-2 | Pwd operation policy | Password operational policy | – |
| Prohibit caching of password for external servers | Prohibit caching of password for external servers | Enable / Disable |
| Display warning when default password is in use | Display warning when default password is in use | Enable / Disable |
| Prohibit use of default password for remote access | Prohibit use of default password for remote access | Enable / Disable |
9-4-3 | Password settings policy | Password settings policy | – |
| Minimum number of characters for password | Set minimum number of characters for password | Enable / Disable |
| characters (1 - 32) | Set minimum number of characters | 1~32 (characters) |
| Password validity period | Set password validity period | Enable / Disable |
| days (1 - 180) | Validity period for password | 1-180 days |
| Prohibit use of 3 or more identical consecutive characters | Prohibit use of 3 or more identical consecutive characters | Enable / Disable |
| Require use of at least 1 uppercase character | Force use of at least 1 uppercase character | Enable / Disable |
| Require use of at least 1 lowercase character | Force use of at least 1 lowercase character | Enable / Disable |
| Require use of at least 1 number | Force use of at least 1 digit | Enable / Disable |
| Require use of at least 1 symbol | Force use of at least 1 symbol | Enable / Disable |
9-4-4 | Lockout policy | Lockout Policy | – |
| Enable lockout | Enable lockout | Enable / Disable |
| Lockout threshold (times) | Lockout Threshold | 1-10 time |
| Lockout period (minutes) | Lockout Period | 1-60 min |
9-5 | Key / Certificate | Key / Certificate function | – |
| Prohibit use of weak encryption | Prohibit use of weak encryption | Enable / Disable |
| Prohibit use of key / certificates with weak encryption | Prohibit use of key / certificate with weak encryption | Enable / Disable |
| Use TPM to store password and key | Use TPM to store password and key | Enable / Disable |
9-6 | Log | Log function | – |
| Force recording of audit log | Force recording of audit log | Enable / Disable |
| Require SNTP settings | Force SNTP settings | Enable / Disable |
| Server name | SNTP server name setting | URL |
9-7 | Job | Job function | – |
9-7-1 | Printing policy | Printing Policy | – |
| Prohibit immediate printing of received jobs | Prohibit immediate printing of received jobs | Enable / Disable |
9-7-2 | Send / Receive policy | Sending / Receiving Policy | – |
| Allow sending only to registered addresses | Allow sending only to registered addresses | Enable / Disable |
| Force confirmation of fax number | Force confirmation of fax number | Enable / Disable |
| Prohibit auto forwarding | Prohibit auto forwarding | Enable / Disable |
9-7-3 | Storage | Storage policy | – |
| Force complete deletion of data | Force complete deletion of data | Enable / Disable |
