Click the
(General Settings) tab to display the Settings (General Settings) dialog box.
In the Settings (General Settings) dialog box, you can set the product to use, file size restriction on e-mail attachment, language to detect text in images, and folder in which to save images temporarily.
The displayed items vary depending on your model.
When the Settings dialog box is displayed from IJ PDF Editor, only Product Name appears.
Product Name
Displays the name of the product that Scan Utility is currently set to use.
If the displayed product is not the one you want to use, select the desired product from the list.
In addition, for network connection, select one with "Network" after the product name.
With a network connection, Select appears on the right side of the product name. Click Select to display Network Scanner Selector EX2 from which you can change the scanner to use.
E-mail Attachment Size
You can restrict the size of scanned images to be attached to an e-mail.
You can select Small (Suitable for 640 x 480 Screen Resolution), Medium (Suitable for 800 x 600 Screen Resolution), Large (Suitable for 1024 x 768 Screen Resolution), or No Change.
Document Language
You can select the language for detecting text in images and for use with search when a PDF file that supports keyword search is created.
Folder to Save Temporary Files
Displays the folder in which to temporarily save images scanned with Scan Utility or IJ PDF Editor. Click Browse... to specify the destination folder.
If you change the Folder to Save Temporary Files while IJ PDF Editor is running, files will be saved to the previous folder. The change will be reflected after restarting IJ PDF Editor.
Instructions
Opens this guide.
Defaults
You can restore the settings in the displayed screen to the default settings.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
____________________________________________________________________________________________
