With Canon PRINT, you can make a copy of a document or a picture using your mobile device. You can also make perspective corrections to printed images using this feature. Follow the steps below to use Smartphone Copy.
From the main menu of Canon PRINT, select Smartphone Copy.
If you receive a prompt stating that Canon PRINT wants to access your camera, select While using the app or the appropriate affirmative response.
If you are prompted to choose an app to make use of this function, select Camera.
You may be asked to specify a folder to save the picture you take. Specify the folder as needed. Select Allow or the appropriate affirmative response after selecting the desired save folder.
Hold a document or photo in front of the camera. Try to keep the document or photo as straight as possible while keeping it entirely in frame. Please note that if you are using an external camera connected to your Chrome OS device, you will need to place your document or photo on a flat, level surface.
Click or tap the shutter button
Selecting the X at the upper right corner will back out of this process.
After you have taken a picture, you will see a preview image. If you want to use this image, select the check mark. If you do not like how this image looks and would like to take another picture of your document or photo, select the X.
The following information will appear:
Select Close to close this information.
The Correct Distortion screen will appear. Here, you can make adjustments to the frame (the green box). You can adjust this frame as needed by dragging a point in one of the corners of the frame, or by dragging one of the points in the middle of each side of the frame.
Select Next to proceed to the next step.
Selecting the question mark will bring up the instructions shown at the beginning of this step.
A preview image will appear. This will show not only the area of the image as shown in the frame, but it will also show that the perspective has been corrected:
You can rotate the image by selecting the rotate icon at the lower left. Selecting the Filter option will bring up some filters you can choose from:
Select your desired filter (or None). Select Save to proceed.
Specify a compression ratio.
A preview screen will appear. Select Next.
The print options screen will appear. Here, you can specify various print settings (number of copies, media type, paper size, etc.). Select Change settings if you want to make any adjustments to the options used for this print. Select Print to begin printing.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
____________________________________________________________________________________________
