Follow the steps below to use your ChromeOS device to sign into Google Drive through the Canon Inkjet Cloud Printing Center.
- From the main screen of Canon PRINT, select Cloud.
- Select Google Drive.
- Read the message shown and select Agree to continue. If you select Disagree, you will return to the main menu of the IJ Cloud Printing Center.
- You will come to a login screen. Select your account if it is listed, or select Use another account to use an account different from the one(s) listed on the screen. If you want to log in with a different account, provide the requested information in order to continue.
You may also be asked to allow Canon Inkjet Printer to access your Google Account. Select Allow or the appropriate affirmative response to proceed if necessary.
- After you have signed in, select Scan.
- Select a folder where you would like to scan something to if desired. Otherwise, select Next. If you want to create a folder to save your scanned image to, select the plus sign.
- You can select the source for your scans as well as the orientation.
Selecting Select source will show:
Selecting Orientation will show:
Set any options as desired and then select Scan.
- When asked to start scanning, select OK.
The scanning process will begin.
- After the scan has been completed, a file will be saved. Select Go to app top to go back to the main menu of Google Drive. Select Exit to return to the main menu of the IJ Cloud Printing Center.
At any time when scanning to Google Drive, select the menu icon
and Exit if you want to leave.
When you select Exit, you will be prompted to pick from one of two options.
Keep me logged in will return you to the IJ Cloud Printing Center. However, you will remain logged into Google Drive (or the cloud service you specified).
Log out will sign you out of Google Drive (or the cloud service you specified) and return you to the IJ Cloud Printing Center.
