Salesforce
MAXIFY GX5120 Easy Wireless Connect Setup - macOS
« Go Back
Information
TitleMAXIFY GX5120 Easy Wireless Connect Setup - macOS
URL NameMAXIFY-GX5120-Easy-Wireless-Connect-Setup-macOS
Description
Use Easy wireless connect to establish the printer's wireless connection to your network.
Solution
Wireless Setup - macOS
To be able to use your printer wirelessly on a Mac®, the printer must first be connected to the wireless network. Then, software needs to be installed on the computer. The instructions / screenshots below show the setup program steps when using the Easy wireless connect method to connect to the wireless network.
The setup process consists of 2 parts:
  1. Starting Easy wireless connect on the printer, and
  2. Downloading and running Canon PRINT to install the software.
Start Easy wireless connect on the printer
Prior to starting setup on the computer, start Easy wireless connect on the printer. Then complete the setup on the computer.
See the procedure below to start Easy wireless connect.
  1. Press and hold the   Wireless connect button until the following appears on the LCD.
    Figure: LCD
Download and run Canon PRINT.
Get Canon PRINT here
After downloading the setup file, drag the the Canon PRINT icon to the Applications folder.
Drag the Canon PRINT icon to the Applications folder
Open the Applications folder on your computer, then open Canon PRINT.
When you first open Canon PRINT, select Do not agree or Agree to continue.
Select Do not agree or Agree
When this screen appears, select Set Up Now.
Click Set Up Now (outlined in red)
Enter your user name and password in the fields provided then select Install Helper.
Select Install Helper (outlined in red)
  1. Select Start Setup on the first screen.
    Click Start Setup (outlined in red)
    The installer will check for the latest information related to your printer.
    Checking the latest information
  2. Read the license agreement. Select Yes to proceed.  If you select No, the installation will not proceed.
    Click Yes (outlined in red) to proceed
  3. Select Agree or Do Not Agree to the information request.
    Click Agree or Do not agree (both outlined in red) to proceed
    This message appears if you selected Do not agree. Click OK to proceed.
    Click OK (outlined in red) to proceed
  4. After processing for a few moments, the installer will display the following message. Select Next.
    Click Next (outlined in red) to proceed
    The installer will search for the printer.
    Searching for printers
  5. The installer will ask you to confirm that you want to connect the printer to your wireless router. Select Connect.
    Click Continue (outlined in red)
    The installer will communicate with the printer.
    Please wait
  6. A message will appear that states to allow keychain access if prompted. Select OK.
    The computer will communicate with the printer. Please wait.
    Please wait
    Select Allow if you're asked to allow access to the keychain.
    Click Allow (outlined in red)
    After a few moments, the connection will be completed.
    The printer is now connected to the network
     If your printer is not detected, make sure that the computer has reconnected to the correct network. Also, you may need to temporarily disable any firewall software, or you may need to open blocked ports in the firewall. If your Mac is connected to a VPN (Virtual Private Network), temporarily disconnect from the VPN and try the setup again. Also, if you are using a dual-band router, further troubleshooting information can be found here.
    The installer will download software, then process for a few moments.
  7. When this screen appears, select Add Printer.
    Click Add Printer (outlined in red)
  8. Select your printer series with Bonjour listed in the Kind column, then click Add.
    Select the printer with Bonjour listed in the Kind column. Select AirPrint or Secure Airprint for Use: and click Add (outlined in red)
  9. Select Next.
  10. After processing for a few moments, the following screen will appear. Select Next.
     If desired, select Test Print to print a test page.
  11. Select Go to Website. The installer will close.
    Click Go to Website (outlined in red) to close the installer
Powered by
