Salesforce
PIXMA PRO-200S Easy Wireless Connect Setup - macOS
« Go Back
Information
TitlePIXMA PRO-200S Easy Wireless Connect Setup - macOS
URL NamePIXMA-PRO-200S-Easy-Wireless-Connect-Setup-macOS
Description
Use Easy wireless connect to establish the printer's wireless connection to your network.
Solution
Before Starting
If the printer is already connected to a wireless network, you do not have to place the printer into Easy wireless connect mode. Click here if the printer is already connected to your wireless network.
Wireless Setup - macOS
To be able to use your printer wirelessly on a Mac, the printer must first be connected to the wireless network. Then, software needs to be installed on the computer. The instructions / screenshots below show the setup program steps when using the Easy wireless connect method to connect to the wireless network.
The setup process consists of 2 parts:
  1. Starting Easy wireless connect on the printer, and
  2. Downloading and running the setup file to install the software.
Start Easy wireless connect on the printer
Prior to starting setup on the computer, start Easy wireless connect on the printer. Then complete the setup on the computer.
See the procedure below to start Easy wireless connect.
  1. On the printer's HOME screen, select LAN settings, then press the OK button.
  2. Wi-Fi will be selected. Press the OK button.
  3. The Wi-Fi setting list will be shown. Press the OK button.
  4. Select Wi-Fi setup, then press the OK button.
  5. Easy wireless connect will be selected. Press the OK button.
  6. The message Connect to a computer or smartphone. Please confirm. will appear. Press the OK button.
    When the following message appears, the printer is ready to receive the information it needs to connect to your wireless network.
    Figure: Follow the instructions on your computer or smartphone.
    Proceed with the computer setup.
Download and run the setup file.
Get the setup file
After downloading the setup file, open it, then double-click on the Master Setup icon.
Master Setup icon
If you are prompted to open this, select Open or the appropriate affirmative option.
Enter your user name and password in the fields provided then select Install Helper.
Select Install Helper (outlined in red)
  1. Select Start Setup on the first screen.
    Click Start Setup (outlined in red)
    The installer will check for the latest information related to your printer.
    Checking the latest information
  2. When this screen appears, you must agree to the License Agreement. Please note that you can choose to agree to the requests to collect information, but you are not required to. Select Next to proceed.
    Click Next (outlined in red)
  3. After processing for a few moments, the installer will display the following message. Select Next.
    Click Yes (outlined in red) to proceed
    The installer will search for the printer.
    Searching for printers
  4. Your printer and the last five characters of its serial number will be shown. Select Connect.
    Click Connect (outlined in red)
    You may see the following message. If so, click OK.
    Click OK (outlined in red)
  5. If prompted, enter your user name and password for your computer, then select Allow.
    Click Allow (outlined in red)
    After a few moments, the printer will be connected to the network.
    The printer is connected
    The installer will download software, then process for a few moments.
  6. When the Add Printer screen appears, select Add Printer.
    Click Add Printer (outlined in red)
  7. Select your printer from the list. Then, for Use:, choose Select Software....
    Choose Select Software...
  8. Choose the printer, then click OK.
    Choose the printer, then click OK (outlined in red)
  9. When the Add Printer dialog, reappears, select Add.
  10. Select Next.
  11. When the following screen appears, select Next.
  12. Select Go to Website. The installer will close.
    Click Go to Website (outlined in red) to close the installer
If your product issue was not resolved after following the steps above, or if you require additional help, please create or log in to your Canon Account to see your technical support options.
Powered by
