Salesforce
Print Out Network Setting Information (LAN Details) - PRO-200S
« Go Back
Information
TitlePrint Out Network Setting Information (LAN Details) - PRO-200S
URL NamePrint-Network-Setting-Information-PRO-200S
Description
This article explains how to print out the network setting information for the PIXMA PRO-200S.
Solution
Before Starting
An example of this information can be found here.
Use the operation panel to print the printer's current network settings.
 The network settings printout contains important information about your network. Handle it with care.
  1. Check that printer is turned on and display the Home screen.
    If the HOME screen is not displayed, press the HOME button.
  2. Load three sheets of A4 or Letter-sized plain paper in the top feed.
  3. Select LAN settings on the Home screen and press the OK button.
  4. Select Print details and press the OK button.
  5. Check the displayed message, select Yes and press the OK button.
  6. When the confirmation screen for printing passwords appears, select Yes or No and press the OK button.
    The printer starts printing the network setting information.
The following information on the printer's network setting is printed out. (Some setting values are not displayed depending on the printer settings.)
Item Number
Item
Description
Setting
1
Product Information
Product information
1-1
Product Name
Product name
XXXXXXXX
1-2
ROM Version
ROM version
XXXXXXXX
1-3
Serial Number
Serial number
XXXXXXXX
1-4
Default Password
Default password (to access Remote UI)
XXXXXXXX
2
Network Diagnostics
Network diagnostics
2-1
Diagnostic Result
Diagnostic result
XXXXXXXX
2-2
Result Codes
Result codes
XXXXXXXX
2-3
Result Code Details
Result code details
http://canon.com/ijnwt
3
Wireless LAN
Wireless LAN
Enable/Disable
3-2
Infrastructure
Infrastructure
Enable/Disable
3-2-1
Signal Strength
Signal strength
0 to 100 [%]
3-2-2
Link Quality
Link quality
0 to 100 [%]
3-2-3
Frequency
Frequency
XX (GHz)
3-2-4
MAC Address
MAC address
XX:XX:XX:XX:XX:XX
3-2-5
Connection
Connection status
Active/Inactive
3-2-6
SSID
SSID
Wireless LAN network name (SSID)
3-2-7
Channel
Channel
XXX (1 to 13, 36, 40, 44, 48, 52, 56, 60, 64, 100, 104, 108, 112, 116, 120, 124, 128, 132, 136, 140, 149, 153, 157, 161, 165)
3-2-8
Encryption
Encryption method
None/WEP/TKIP/AES
3-2-9
WEP Key Length
WEP key length (bits)
Inactive/128/64
3-2-10
Authentication
Authentication method
None/auto/open/shared/WPA-PSK/WPA2-PSK
3-2-11
TCP/IPv4
TCP/IPv4
Enable/Disable
3-2-12
IP Address
IP address
XXX.XXX.XXX.XXX
3-2-13
Subnet Mask
Subnet mask
XXX.XXX.XXX.XXX
3-2-14
Default Gateway
Default gateway
XXX.XXX.XXX.XXX
3-2-15
TCP/IPv6
TCP/IPv6
Enable/Disable
3-2-16
Link Local Address
Link local address
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-17
Link Local Prefix Length
Link local prefix length
XXX
3-2-18
Stateless Address1
Stateless address 1
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-19
Stateless Prefix Length1
Stateless prefix length 1
XXX
3-2-20
Stateless Address2
Stateless address 2
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-21
Stateless Prefix Length2
Stateless prefix length 2
XXX
3-2-22
Stateless Address3
Stateless address 3
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-23
Stateless Prefix Length3
Stateless prefix length 3
XXX
3-2-24
Stateless Address4
Stateless address 4
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-25
Stateless Prefix Length4
Stateless prefix length 4
XXX
3-2-26
Default Gateway1
Default gateway 1
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-27
Default Gateway2
Default gateway 2
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-28
Default Gateway3
Default gateway 3
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-29
Default Gateway4
Default gateway 4
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-30
Manual Setting
Manual Setting
Enable/Disable
3-2-31
IP Address
IP Address
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-32
Subnet Prefix Length
XXX
3-2-33
IPsec
IPsec setting
Active/Inactive
3-2-34
Security Protocol
Security method
ESP/ESP & AH/AH/Blank (not selected)
3-2-35
Wireless LAN DRX
Discontinuous reception (wireless LAN)
Enable/Disable
3-3
Wireless Direct
Operation mode for Wireless Direct
Enable/Disable
3-3-1
MAC Address
MAC address
XX:XX:XX:XX:XX:XX
3-3-2
Connection
Connection status
Active/Inactive
3-3-3
SSID
SSID
Wireless Direct network name (SSID)
3-3-4
Password
Password
Wireless Direct password
3-3-5
Channel
Channel
3
3-3-6
Encryption
Encryption method
AES
3-3-7
Authentication
WPA2-PSK
3-3-8
TCP/IPv4
TCP/IPv4
Enable/Disable
3-3-9
IP Address
IP address
XXX.XXX.XXX.XXX
3-3-10
Subnet Mask
Subnet mask
XXX.XXX.XXX.XXX
3-3-11
Default Gateway
Default gateway
XXX.XXX.XXX.XXX
3-3-12
TCP/IPv6
TCP/IPv6
Enable/Disable
3-3-13
Link Local Address
Link local address
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-3-14
XXX
3-3-15
IPsec
IPsec setting
Active/Inactive
3-3-16
Security Protocol
Security method
3-3-17
Wireless LAN DRX
Discontinuous reception (wireless direct)
Enable/Disable
4
Wired LAN
Wired LAN
Enable/Disable
4-1
MAC Address
MAC Address
XX:XX:XX:XX:XX:XX
4-2
Connection
Connection
Active/Inactive
4-3
TCP/IPv4
Operation mode for TCP/IPv4
Enable/Disable
4-4
IP Address
IP Address
XXX.XXX.XXX.XXX
4-5
Subnet Mask
Subnet Mask
XXX.XXX.XXX.XXX
4-6
Default Gateway
Default Gateway
XXX.XXX.XXX.XXX
4-7
TCP/IPv6
Operation mode for TCP/IPv6
Enable/Disable
4-8
Link Local Address
Link Local Address
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
4-9
XXX
4-10
Stateless Address1
Stateless Address1
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
4-11
XXX
4-12
Stateless Address2
Stateless Address2
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
4-13
XXX
4-14
Stateless Address3
Stateless Address3
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
4-15
XXX
4-16
Stateless Address4
Stateless Address4
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
4-17
XXX
4-18
Default Gateway1
Default Gateway1
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
4-19
Default Gateway2
Default Gateway2
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
4-20
Default Gateway3
Default Gateway3
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
4-21
Default Gateway4
Default Gateway4
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
4-22
Manual Setting
Manual Setting
Enable/Disable
4-23
IP Address
IP Address
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
4-24
XXX
4-25
IPsec
IPsec
Active/Inactive
4-26
Security Protocol
Security Protocol
4-27
Wired LAN DRX
Wired LAN DRX
Enable/Disable
5
Other Settings
Other settings
5-1
Printer Name
Printer name
Printer name (Up to 15 alphanumeric characters)
5-2
Wireless Direct DevName
Device name for wireless direct
Device name for wireless direct (Up to 32 alphanumeric characters)
5-4
WSD Printing
WSD printing setting
Enable/Disable
5-5
WSD Timeout
Timeout
1/5/10/15/20 [min]
5-6
LPD Printing
LPD printing setting
Enable/Disable
5-7
RAW Printing
RAW printing setting
Enable/Disable
5-9
Bonjour
Bonjour setting
Enable/Disable
5-10
Bonjour Service Name
Bonjour service name
Bonjour service name (Up to 52 alphanumeric characters)
5-11
LLMNR
LLMNR setting
Enable/Disable
5-12
SNMP
SNMP setting
Enable/Disable
5-13
PictBridge Commun.
PictBridge Communication
Enable/Disable
5-14
DNS Server
Obtain DNS server address automatically
Auto/Manual
5-15
Primary Server
Primary server address
XXX.XXX.XXX.XXX
5-16
Secondary Server
Secondary server address
XXX.XXX.XXX.XXX
5-17
Proxy Server
Proxy server setting
Enable/Disable
5-18
Proxy Address
Proxy address
XXXXXXXXXXXXXXXXXXXX
5-19
Proxy Port
Proxy port specification
1 to 65535
5-20
Cert. Fingerprt(SHA-1)
Certificate fingerprint(SHA-1)
xxxxxxxx xxxxxxxx xxxxxxxx
xxxxxxxx xxxxxxxx
5-21
Cert. Fingerprt(SHA-256)
Certificate fingerprint(SHA-256)
xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx
7
Web Services
Web Services
7-1
Unsent Usage Logs
Number of unsent usage logs
0 to 200
7-2
Usage Log Last Sent
Last date when usage log was sent
XXXXXXXX
7-3
Web Service Status
Registration status
Not set/Disabled/Registration pending/Registered
7-4
Log Transmission Status
Transmission result
Not activated/Processing/Server error/Connection error/Timeout error/Error/Awaiting server response/Active
("XX" represents alphanumeric characters.)
Powered by
