Follow the steps below to print the LAN details page.
Print the LAN details page
The network settings printout contains important information about your network. Please keep it in a safe place.
Make sure the printer is powered on.
Load three sheets of A4 or Letter-sized plain paper.
Select the Setup icon
on the HOME screen and press the OK button.
Select LAN settings and press OK button.
Select Print details and press OK button.
Select Yes and press the OK button.
Review the displayed message and press the OK button.
When print passwords confirmation screen appears, select ON or OFF and press the OK button.
The printer prints out the LAN details page.
The information in the table below about printer's network setting is printed out. Some setting values are not displayed based on the printer settings.
Item Number
Item
Description
Setting
1
Product Information
Product information
1-1
Product Name
Product name
XXXXXXXX
1-2
ROM Version
ROM version
XXXXXXXX
1-3
Serial Number
Serial number
XXXXXXXX
1-4
Default Password
Default password (to access Remote UI)
XXXXXXXX
2
Network Diagnostics
Network diagnostics
2-1
Diagnostic Result
Diagnostic result
XXXXXXXX
2-2
Result Codes
Result codes
XXXXXXXX
2-3
Result Code Details
Result code details
http://canon.com/ijnwt
3
Wireless LAN
Wireless LAN
Enable/Disable
3-2
Infrastructure
Infrastructure
Enable/Disable
3-2-1
Signal Strength
Signal strength
0 to 100 [%]
3-2-2
Link Quality
Link quality
0 to 100 [%]
3-2-3
Frequency
Frequency
XX (GHz)
3-2-4
MAC Address
MAC address
XX:XX:XX:XX:XX:XX
3-2-5
Connection
Connection status
Active/Inactive
3-2-6
SSID
SSID
Wireless LAN network name (SSID)
3-2-7
Channel
Channel
XX (1 to 13)
3-2-8
Encryption
Encryption method
None/WEP/TKIP/AES
3-2-9
WEP Key Length
WEP key length (bits)
Inactive/128/64
3-2-10
Authentication
Authentication method
None/auto/open/shared/WPA-PSK/WPA2-PSK
3-2-11
TCP/IPv4
TCP/IPv4
Enable
3-2-12
IP Address
IP address
XXX.XXX.XXX.XXX
3-2-13
Subnet Mask
Subnet mask
XXX.XXX.XXX.XXX
3-2-14
Default Gateway
Default gateway
XXX.XXX.XXX.XXX
3-2-15
TCP/IPv6
TCP/IPv6
Enable/Disable
3-2-16
Link Local Address
Link local address
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-17
Link Local Prefix Length
Link local prefix length
XXX
3-2-18
Stateless Address1
Stateless address 1
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-19
Stateless Prefix Length1
Stateless prefix length 1
XXX
3-2-20
Stateless Address2
Stateless address 2
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-21
Stateless Prefix Length2
Stateless prefix length 2
XXX
3-2-22
Stateless Address3
Stateless address 3
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-23
Stateless Prefix Length3
Stateless prefix length 3
XXX
3-2-24
Stateless Address4
Stateless address 4
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-25
Stateless Prefix Length4
Stateless prefix length 4
XXX
3-2-26
Default Gateway1
Default gateway 1
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-27
Default Gateway2
Default gateway 2
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-28
Default Gateway3
Default gateway 3
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-29
Default Gateway4
Default gateway 4
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-33
IPsec
IPsec setting
Active
3-2-34
Security Protocol
Security method
ESP/ESP & AH/AH
3-3
Wireless Direct
Operation mode for Wireless Direct
Enable/Disable
3-3-1
MAC Address
MAC address
XX:XX:XX:XX:XX:XX
3-3-2
Connection
Connection status
Active/Inactive
3-3-3
SSID
SSID
Wireless Direct network name (SSID)
3-3-4
Password
Password
Wireless Direct password (10 alphanumeric characters)
3-3-5
Channel
Channel
3
3-3-6
Encryption
Encryption method
AES
3-3-7
Authentication
WPA2-PSK
3-3-8
TCP/IPv4
TCP/IPv4
Enable
3-3-9
IP Address
IP address
XXX.XXX.XXX.XXX
3-3-10
Subnet Mask
Subnet mask
XXX.XXX.XXX.XXX
3-3-11
Default Gateway
Default gateway
XXX.XXX.XXX.XXX
3-3-12
TCP/IPv6
TCP/IPv6
Enable/Disable
3-3-13
Link Local Address
Link local address
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-3-14
XXX
3-3-15
IPsec
IPsec setting
Active
3-3-16
Security Protocol
Security method
3-3-17
Wireless LAN DRX
Discontinuous reception (wireless direct)
Enable/Disable
5
Other Settings
Other settings
5-1
Printer Name
Printer name
Printer name (Up to 15 alphanumeric characters)
5-2
Wireless Direct DevName
Device name for wireless direct
Device name for wireless direct (Up to 32 alphanumeric characters)
5-4
WSD Printing
WSD printing setting
Enable/Disable
5-5
WSD Timeout
Timeout
1/5/10/15/20 [min]
5-6
LPD Printing
LPD printing setting
Enable/Disable
5-7
RAW Printing
RAW printing setting
Enable/Disable
5-9
Bonjour
Bonjour setting
Enable/Disable
5-10
Bonjour Service Name
Bonjour service name
Bonjour service name (Up to 52 alphanumeric characters)
5-11
LLMNR
LLMNR setting
Enable/Disable
5-12
SNMP
SNMP setting
Enable/Disable
5-13
PictBridge Commun.
PictBridge Communication
Enable/Disable
5-14
DNS Server
Obtain DNS server address automatically
Auto/Manual
5-15
Primary Server
Primary server address
XXX.XXX.XXX.XXX
5-16
Secondary Server
Secondary server address
XXX.XXX.XXX.XXX
5-17
Proxy Server
Proxy server setting
Enable/Disable
5-18
Proxy Address
Proxy address
XXXXXXXXXXXXXXXXXXXX
5-19
Proxy Port
Proxy port specification
1 to 65535
5-20
Cert. Fingerprt(SHA-1)
Certificate fingerprint(SHA-1)
xxxxxxxx xxxxxxxx xxxxxxxx
xxxxxxxx xxxxxxxx
5-21
Cert. Fingerprt(SHA-256)
Certificate fingerprint(SHA-256)
xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx
