Salesforce
imagePROGRAF PRO-310 Easy Wireless Connect Setup - Windows
« Go Back
Information
TitleimagePROGRAF PRO-310 Easy Wireless Connect Setup - Windows
URL NameiPF-PRO-310-Easy-Wireless-Connect-Setup-Windows
Description
Use Easy wireless connect to establish the printer's wireless connection to your network.
Solution
Before Starting
If the printer is already connected to a wireless network, you do not have to place the printer into Easy wireless connect mode. Click here if the printer is already connected to your wireless network.
Wireless Setup - Windows
To be able to use your printer wirelessly on a Windows PC, the printer must first be connected to the wireless network. Then, software needs to be installed on the computer. The instructions / screenshots below show the setup program steps when using the Easy wireless connect method to connect to the wireless network.
The setup process consists of 2 parts:
  1. Starting Easy wireless connect on the printer, and
  2. Downloading and running the setup file to install the software.
Start Easy wireless connect on the printer
Prior to starting setup on the computer, start Easy wireless connect on the printer. Then complete the setup on the computer.
See the procedure below to start Easy wireless connect.
  1. On the printer's HOME screen, select LAN settings, then press the OK button.
  2. Wi-Fi will be selected. Press the OK button.
  3. Select Wi-Fi setup. Press the OK button.
  4. Easy wireless connect will be selected. Press the OK button.
  5. The message Easy wireless connect is available. Do you want to connect to a computer or smartphone now? will appear. Press the OK button.
    When the following message appears, the printer is ready to receive the information it needs to connect to your wireless network.
    Figure: Follow the instructions on your computer or smartphone.
    Proceed with the computer setup.
Download and run the setup file.*
Get the Setup File
After downloading the setup file, open it. If you're prompted to provide permission to open the file, select Open or the appropriate affirmative option.
  1. Select your language, then click OK.
    Select your language, then click OK (outlined in red)
  2. Select your place of residence, then click OK.
    Select your place of residence, then click OK (outlined in red)
  3. Select Start Setup.
    Click Start Setup (outlined in red)
    The installer will check for the latest information related to your printer.
    Checking the latest information
  4. In order to proceed, you must agree to the License Agreement. Click License Agreement to read it, then place a check in the box next to Agree. You may also choose to agree to requests for information from Canon by placing a check in the appropriate boxes. Click Next to proceed.
    Click Next (outlined in red) to proceed
  5. After processing for a few moments, the installer will display the following message. Select Next.
    The installer will search for the printer.
    Searching for printers
  6. The installer will ask you to confirm that you want to connect the printer to your wireless router. Select Connect.
    Click Connect (outlined in red)
  7. The computer will communicate with the printer. Please wait.
    Please wait
    After a few moments, the connection will be completed.
    The printer is now connected to the network
     If your printer is not detected, make sure that the computer has reconnected to the correct network. Also, you may need to temporarily disable any firewall software, or you may need to open blocked ports in the firewall. If your PC is connected to a VPN (Virtual Private Network), temporarily disconnect from the VPN and try the setup again. Also, if you are using a dual-band router, further troubleshooting information can be found here.
  8. The installer will download the software and drivers.
    Click Add Printer (outlined in red)
    The printer driver will be installed. Please wait.
    Installing the printer driver
  9. The printer will be registered into your computer. Please wait.
    Please wait
  10. After processing for a few moments, the following screen will appear. Select Next.
  11. Select Go to Website. The installer will close.
    Click Go to Website (outlined in red) to close the installer
If your product issue was not resolved after following the steps above, or if you require additional help, please create or log in to your Canon Account to see your technical support options.
Powered by
