Salesforce
Print the LAN details (network settings) - MX410
« Go Back
Information
TitlePrint the LAN details (network settings) - MX410
URL NameART109636
Description
This article explains how to print a Network Configuration Page for the PIXMA MX410.  An example of this page is attached to this article.
Solution
Printing Out Network Setting Information
You can print out the network settings of the machine such as its IP address and SSID.
Note: The steps listed below are specific to the MX410.  For instructions for other models, click here
Important
  • This print out contains valuable information about your computer. Handle it with care.
  1. Make sure that the machine is turned on.
  2. Load a sheet of A4 or Letter-sized plain paper in the Rear Tray.
  3. Press the Menu button repeatedly and select Device settings.
  4. Use the LEFT RIGHT button to select LAN settings, then press the OK button.
  5. Use the LEFT RIGHT button to select Print LAN details, then press the OK button.
    The following information on the machine's network setting is printed out.
    Item
    Explanations of the item
    Setting
    Wireless LAN
    Wireless LAN
    Enable/Disable
    Link Status
    Status of the Wireless LAN
    Active/Inactive
    MAC Address
    MAC Address
    XX:XX:XX:XX:XX:XX
    SSID
    SSID
    SSID of the wireless LAN
    Connection Mode
    Connection Mode
    Infrastructure
    Channel
    Channel
    XX (1 to 13)
    Encryption
    Method of the Encryption
    none/WEP/TKIP/AES
    WEP Key Length
    WEP Key Length
    Inactive/128/64
    Authentication
    Method of the Authentication
    none/auto/open/shared/WPA-PSK/WPA2-PSK
    Signal Strength
    Signal Strength
    0 to 100 [%]
    TCP/IP Version
    TCP/IP Version
    IPv4/IPv6
    IP Address
    Selected IP Address
    XXX.XXX.XXX.XXX
    Default Gateway
    Default Gateway
    XXX.XXX.XXX.XXX
    Subnet Mask*1
    Subnet Mask
    XXX.XXX.XXX.XXX
    Subnet Prefix Length*2
    XXX
    IPsec*3
    IPsec setting
    Active
    Security Protocol*3
    Method of the Security Protocol
    ESP/ESP & AH/AH
    Printer Name
    Printer name
    Printer name (Up to 15 characters)
    WSD
    WSD setting
    Enable/Disable
    WSD Timeout
    Timeout
    1/5/10/15/20 [min]
    LLTD
    LLTD setting
    Enable/Disable
    LPR Protocol
    LPR protocol setting
    Enable/Disable
    Bonjour
    Bonjour setting
    Enable/Disable
    Bonjour Service Name
    Bonjour service name
    Bonjour service name (Up to 52 characters)
    Bonjour LPR Service
    Bonjour LPR service advertising
    Enable/Disable
    IP Address FilteringIP Address FilteringEnable/Disable
    ("X" represents an alphanumeric character ranging from 0 to 9 and A to F.)
    *1 Only when IPv4 is selected on IPv4/IPv6 setting, the status of the network is printed.
    *2 Only when IPv6 is selected on IPv4/IPv6 setting, the status of the network is printed.
    *3 Only when IPv6 is selected on IPv4/IPv6 setting and Active is selected on IPsec settings, the status of the network is printed.
Page top
Powered by
