Follow the steps below to get a printout of the network settings for your printer, such as the IP address and network name (SSID).
Get a network settings printout
The steps listed below are specific to the PIXMA MG3120 and MG3122. Get instructions for other models.
This printout contains valuable information about your computer. Handle it with care.
Make sure your printer is turned ON.
Load a sheet of A4 or Letter-sized plain paper.
Press the Maintenance button repeatedly until the LED displays as below:
Press the Color button or the Black button on the printer. The machine will produce a printout similar to the one below.
Sample Printout
Your machine will produce a printout unique to your network.
Item | Explanations of the item | Setting |
Wireless LAN | Wireless LAN | Enable/Disable |
Link Status | Status of the Wireless LAN | Active/Inactive |
MAC Address | MAC Address | XX:XX:XX:XX:XX:XX |
SSID | Network Name | SSID of the wireless LAN |
Connection Mode | Connection Mode | Infrastructure |
Channel | Channel | XX (1 to 13) |
Encryption | Method of the Encryption | none/WEP/TKIP/AES |
WEP Key Length | WEP Key Length | Inactive/128/64 |
Authentication | Method of the Authentication | none/auto/open/shared/WPA-PSK/WPA2-PSK |
Signal Strength | Signal Strength | 0 to 100 [%] |
TCP/IP Version | TCP/IP Version | IPv4/IPv6 |
IP Address | Selected IP Address | XXX.XXX.XXX.XXX |
Default Gateway | Default Gateway | XXX.XXX.XXX.XXX |
Subnet Mask*1 | Subnet Mask | XXX.XXX.XXX.XXX |
Subnet Prefix Length*2 | Subnet Prefix Length | XXX |
IPsec*3 | IPsec setting | Active |
Security Protocol*3 | Method of the Security Protocol | ESP/ESP & AH/AH |
WPS PIN CODE | WPS PIN Code | XXXXXXXX (Up to 8 characters) |
Printer Name | Printer name | Printer name (Up to 15 characters) |
WSD | WSD setting | Enable/Disable |
WSD Timeout | Timeout | 1/5/10/15/20 [min] |
LPR Protocol | LPR protocol setting | Enable/Disable |
Bonjour | Bonjour setting | Enable/Disable |
Bonjour Service Name | Bonjour service name | Bonjour service name (Up to 52 characters) |
IP Address Filtering | IP Address Filtering | Enable/Disable |
("X" represents an alphanumeric character ranging from 0 to 9 and A to F.)
*1 Only when the TCP/IP version is IPv4, the status of the network is printed.
*2 Only when the TCP/IP version is IPv6, the status of the network is printed.
*3 Only when the TCP/IP version is IPv6 and the IP sec setting is activated, the status of the network is printed.
