Printing Out Network Setting Information
You can print out the network settings of the printer such as its IP address and SSID
This print out contains valuable information about your computer. Handle it with care
Confirm that the printer is powered on.
Load a sheet of Letter-sized (A4) plain paper.
Press and hold the RESUME / CANCEL button, then release the button when the POWER lamp flashes white 6 times
The printer starts printing the network setting information
The following information on the printer's network settings is printed out.
Item | Explanations of the item | Setting |
Wireless LAN | Wireless LAN | Enable/Disable |
Connection | Status of the Wireless LAN | Active/Inactive |
MAC Address | MAC Address | XX:XX:XX:XX:XX:XX |
SSID | SSID | SSID of the wireless LAN |
Communication Mode | Communication Mode | Infrastructure |
Channel | Channel | XX (1 to 13) |
Encryption | Method of the Encryption | none/WEP/TKIP/AES |
WEP Key Length | WEP Key Length | Inactive/128/64 |
Authentication | Method of the Authentication | none/auto/open/shared/WPA-PSK/WPA2-PSK |
Signal Strength | Signal Strength | 0 to 100 [%] |
TCP/IP Version | TCP/IP Version | IPv4 & IPv6/IPv4 |
IPv4 IP Address | Selected IP Address (IPv4) | XXX.XXX.XXX.XXX |
IPv4 Default Gateway | Default Gateway (IPv4) | XXX.XXX.XXX.XXX |
Subnet Mask | Subnet Mask | XXX.XXX.XXX.XXX |
IPv6 IP Address *1 | Selected IP Address (IPv6) | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
IPv6 Default Gateway *1 | Default Gateway (IPv6) | XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX |
Subnet Prefix Length*1 | Subnet Prefix Length | XXX |
IPsec*2 | IPsec setting | Active |
Security Protocol*2 | Method of the Security Protocol | ESP/ESP & AH/AH |
WPS PIN CODE | WPS PIN code | XXXXXXXX |
Wireless LAN DRX | Discontinuous reception (wireless LAN) | Enable/Disable |
Other Settings | Other settings | - |
Printer Name | Printer name | Printer name (Up to 15 characters) |
WSD | WSD setting | Enable/Disable |
WSD Timeout | Timeout | 1/5/10/15/20 [min] |
LPR Protocol | LPR protocol setting | Enable/Disable |
Bonjour | Bonjour setting | Enable/Disable |
Bonjour Service Name | Bonjour service name | Bonjour service name (Up to 52 characters) |
PictBridge Commun. | PictBridge Communication | Enable/Disable |
DNS Server | Getting DNS Server automatically | Auto/Manual |
Primary Server | Primary server address | XXX.XXX.XXX.XXX |
Secondary Server | Secondary server address | XXX.XXX.XXX.XXX |
Proxy Server | Proxy Server setting | Enable/Disable |
Proxy Port | Specifying Proxy Port | 1 to 65535 |
Proxy Address | Proxy Address | XXXXXXXXXXXXXXXXXXXX |
IP Address Filtering | IP Address Filtering | Enable/Disable |
Default Password *3 | Default password (for accessing Remote UI) | XXXXXXXX |
("XX" represents alphanumeric characters.)
*1 Only when IPv6 is activated, the status of the network is printed.
*2 Only IPv6 and the IPsec setting are activated, the status of the network is printed.
*3 Firmware version 3.000 later is required.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
____________________________________________________________________________________________
