Salesforce
Canon IJ Printer Utility (Mac)
« Go Back
Information
TitleCanon IJ Printer Utility (Mac)
URL NameART116178
Description
This article provides an overview of the Canon IJ Printer Utility. This utility is built into the CUPS printer driver for your printer.
Solution
The Canon IJ Printer Utility allows you to perform printer maintenance or change the settings of the printer.
What You Can Do with the Canon IJ Printer Utility
figure:Canon IJ Printer Utility
You can switch between pages in Canon IJ Printer Utility by the pop-up menu. You can choose one of the following items from the pop-up menu.
Cleaning
Clean the printer to clear up clogged print head nozzles.
Test Print
Execute a test print to check the condition of the print head nozzles and to adjust the print head position.
Power Settings
Operate the power of this printer from the printer driver.
Ink Level Information
Check the remaining ink levels.
Quiet Settings
You can reduce the operating noise of the printer.
Custom Settings
Change the settings of this printer.
Note
  • To operate the Canon IJ Printer Utility, you must first turn on the printer.
  • Depending on the items selected, the computer communicates with the printer to obtain information. If the computer is unable to communicate with the printer, an error message may be displayed.
    If this happens, click Cancel to display the most recent settings specified on your computer.
Powered by
