Salesforce
Print the Wireless Network Settings - PIXMA MG2920 Series
« Go Back
Information
TitlePrint the Wireless Network Settings - PIXMA MG2920 Series
URL NameART116814
Description
Learn how to get a printout of the network configuration (network settings) for your PIXMA MG2900 series printer.
Solution
Follow the steps below to get a printout of the current network settings for your printer. You can also print network information from your browser.
Caution This printout contains valuable information about your computer. Handle it with care.
  1. Turn the printer ON.
  2. Load a sheet of A4 or Letter-sized plain paper.
  3. Press and hold the Stop button until the lamp flashes 15 times, then release the button.
The machine prints network setting information similar to what you see below.
Note If your printer is in Access Point mode, the signal strength is blank.
Sample printout
Item
Explanations of the item
Setting
Wireless LAN
Wireless LAN
Enable/Disable
Connection
Connection status
Active/Inactive
MAC Address
MAC Address
XX:XX:XX:XX:XX:XX
SSID
SSID
SSID of the wireless network/SSID of the router
Password
Password
Password of the access point mode (8 to 10 alphanumeric characters)
Communication Mode
Communication Mode
Infrastructure/Access Point Mode
Channel *1
Channel
XX (1 to 13)
Encryption
Method of the Encryption
none/WEP/TKIP/AES
WEP Key Length
WEP Key Length
Inactive/128/64
Authentication
Method of the Authentication
none/auto/open/shared/WPA-PSK/WPA2-PSK
Signal Strength
Signal Strength
0 to 100 [%] (Will be blank in Access Point mode)
TCP/IP Version
TCP/IP Version
IPv4 & IPv6/IPv4
IPv4 IP Address
Selected IP Address (IPv4)
XXX.XXX.XXX.XXX ***
Enter this number in a web browser to access the Remote UI.
IPv4 Default Gateway
Default Gateway (IPv4)
XXX.XXX.XXX.XXX
Subnet Mask
Subnet Mask
XXX.XXX.XXX.XXX
IPv6 IP Address *2
Selected IP Address (IPv6)
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
IPv6 Default Gateway *2
Default Gateway (IPv6)
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
Subnet Prefix Length *2
XXX
IPsec *3
IPsec setting
Active
Security Protocol *3
Method of the Security Protocol
ESP/ESP & AH/AH
WPS PIN CODE
WPS PIN code
XXXXXXXX
Wireless LAN DRX
Discontinuous reception (wireless LAN)
Enable/Disable
Other Settings
Other settings
Printer Name
Printer name
Printer name (Up to 15 alphanumeric characters)
WSD
WSD setting
Enable/Disable
WSD Timeout
Timeout
1/5/10/15/20 [min]
LPR Protocol
LPR protocol setting
Enable/Disable
Bonjour
Bonjour setting
Enable/Disable
Bonjour Service Name
Bonjour service name
Bonjour service name (Up to 52 alphanumeric characters)
PictBridge Commun.
PictBridge Communication
Enable/Disable
DNS Server
Getting DNS Server automatically
Auto/Manual
Primary Server
Primary server address
XXX.XXX.XXX.XXX
Secondary Server
Secondary server address
XXX.XXX.XXX.XXX
Proxy Server
Proxy Server setting
Enable/Disable
Proxy Port
Specifying Proxy Port
1 to 65535
Proxy Address
Proxy Address
XXXXXXXXXXXXXXXXXXXX
("XX" represents alphanumeric characters.)
*1 Depending on the country or region of purchase, one of the channels from 1 to 11 prints.
*2 The status of the network prints only when IPv6 is enabled.
*3 The status of the network prints only when the IPv6 and the IPsec settings are enabled.
Powered by
