Note: The steps listed below are specific to the MG4120. For instructions for other models, click here
You can print out the network settings of the machine such as its IP address and SSID.
This print out contains valuable information about your computer. Handle it with care.
Make sure that the machine is turned on.
Confirming that the Power Is On
Load a sheet of A4 or Letter-sized plain paper.
Loading paper
Select Setup on the HOME screen.
LCD and Operation Panel
Select Device settings, then use the OK button to confirm the selection.
Use the button to select LAN settings, then use the OK button to confirm the selection.
Use the button to select Confirm LAN settings, then use the OK button to confirm the selection.
Use the button to select Print LAN details, then use the OK button to confirm the selection.
Use the button to select Yes, then use the OK button to start printing.
The machine starts printing the network setting information.
The following information on the machine's network setting is printed out.
Item
Explanations of the item
Setting
Wireless LAN
Enable/Disable
Link Status
Status of the Wireless LAN
Active/Inactive
MAC Address
XX:XX:XX:XX:XX:XX
SSID
SSID of the wireless LAN
Connection Mode
Infrastructure
Channel
XX (1 to 13)
Encryption
Method of the Encryption
none/WEP/TKIP/AES
WEP Key Length
Inactive/128/64
Authentication
Method of the Authentication
none/auto/open/shared/WPA-PSK/WPA2-PSK
Signal Strength
0 to 100 [%]
TCP/IP Version
IPv4/IPv6
IP Address
Selected IP Address
XXX.XXX.XXX.XXX
Default Gateway
Subnet Mask*1
Subnet Mask
Subnet Prefix Length*2
XXX
IPsec*3
IPsec setting
Active
Security Protocol*3
Method of the Security Protocol
ESP/ESP & AH/AH
Wired LAN
Status of the Wired LAN
Printer Name
Printer name
Printer name (Up to 15 characters)
Shared Memory Card
Memory card sharing
WSD
WSD setting
WSD Timeout
Timeout
1/5/10/15/20 [min]
LPR Protocol
LPR protocol setting
Bonjour
Bonjour setting
Bonjour Service Name
Bonjour service name
Bonjour service name (Up to 52 characters)
DNS Server
Getting DNS Server automatically
Auto/Manual
Primary Server
Primary server address
Secondary Server
Secondary server address
Proxy Server
Proxy Server setting
Proxy Port
Specifying Proxy Port
1 to 65535
Proxy Address
XXXXXXXXXXXXXXXXXXXX
IP Address Filtering
("X" represents an alphanumeric character ranging from 0 to 9 and A to F.)
*1 Only when IPv4 is selected for TCP/IP settings, the status of the network is printed.
*2 Only when IPv6 is selected for TCP/IP settings, the status of the network is printed.
*3 Only when IPv6 is selected for TCP/IP settings and Active is selected for IPsec settings, the status of the network is printed.
