Salesforce
How to print Out the Network Settings Information - MP990
« Go Back
Information
TitleHow to print Out the Network Settings Information - MP990
URL NameART136777
Description
This article explains how to print out the network setting information (LAN details) for the PIXMA MP990.  An example of this information is attached to the bottom of this article.
Solution
Note: The steps listed below are specific to the MP990.  For instructions for other models, click here
You can print out the network settings of the machine such as its IP address and SSID.
Important
  • This print out contains valuable information about your computer. Handle it with care.
    1. Make sure that the machine is turned on.
    2. Load a sheet of A4 or Letter-sized plain paper in the Cassette.
    3. Select Settings on the HOME screen, then press the OK button.
    4. Select Device settings, then press the OK button.
    5. Select LAN settings, then press the OK button.
    6. Select Confirm LAN settings, then press the OK button.
    7. Select Print LAN details, then press the OK button.
    8. Select Yes, then press the OK button.
      The following information on the machine's network setting is printed out.
      Item
      Explanations of the item
      Setting
      Wireless LAN
      Wireless LAN
      Enable/Disable
      Link Status
      Status of the Wireless LAN
      Active/Inactive
      MAC Address
      MAC Address
      XX:XX:XX:XX:XX:XX
      SSID
      SSID
      SSID of the wireless LAN
      Connection Mode
      Connection Mode
      Infrastructure
      Channel
      Channel
      XX (1 to 13)
      Encryption
      Method of the Encryption
      none/WEP/TKIP/AES
      WEP Key Length
      WEP Key Length
      Inactive/128/64
      Authentication
      Method of the Authentication
      auto/open/shared/WPA-PSK/WPA2-PSK
      Signal Strength
      Signal Strength
      0 to 100 [%]
      TCP/IP Version
      TCP/IP Version
      IPv4/IPv6
      IP Address
      Selected IP Address
      XXX.XXX.XXX.XXX
      Default Gateway
      Default Gateway
      XXX.XXX.XXX.XXX
      Subnet Mask*1
      Subnet Mask
      XXX.XXX.XXX.XXX
      Subnet Prefix Length*2
      XXX
      IPsec*3
      IPsec setting
      Active
      Security Protocol*3
      Method of the Security Protocol
      ESP/ESP & AH/AH
      Wired LAN
      Wired LAN
      Enable/Disable
      Link Status
      Status of the Wired LAN
      Active/Inactive
      MAC Address
      MAC Address
      XX:XX:XX:XX:XX:XX
      TCP/IP Version
      TCP/IP Version
      IPv4/IPv6
      IP Address
      IP Address
      XXX.XXX.XXX.XXX
      Default Gateway
      Default Gateway
      XXX.XXX.XXX.XXX
      Subnet Mask*1
      Subnet Mask
      XXX.XXX.XXX.XXX
      XXX
      IPsec*3
      IPsec setting
      Active
      Security Protocol*3
      ESP/ESP & AH/AH
      Printer Name
      Printer name
      Printer name (Up to 15 characters)
      Shared Memory Card
      Memory card sharing
      Enable/Disable
      WSD
      WSD setting
      Enable/Disable
      WSD Timeout
      Timeout
      1/5/10/15/20 [min]
      LLTD
      LLTD setting
      Enable/Disable
      LPR Protocol
      LPR protocol setting
      Enable/Disable
      Bonjour
      Bonjour setting
      Enable/Disable
      Bonjour Service Name
      Bonjour service name
      Bonjour service name (Up to 52 characters)
      Bonjour LPR Service
      Bonjour LPR service advertising
      Enable/Disable
      ("X" represents an alphanumeric character ranging from 0 to 9 and A to F.)
      *1 Only when IPv4 is selected on IPv4/IPv6 settings, the status of the network is printed.
      *2 Only when IPv6 is selected on IPv4/IPv6 settings, the status of the network is printed.
      *3 Only when IPv6 is selected on IPv4/IPv6 settings and Active is selected on IPsec Settings, the status of the network is printed.
Powered by
