Note: The steps listed below are specific to the MX432 and MX439 printers. For instructions for other models, click here
Printing Out Network Setting Information
You can print out the network settings of the machine such as its IP address and SSID.
Important
Make sure that the machine is turned on.
Load a sheet of A4 or Letter-sized plain paper in the Rear Tray.
Press the Setup button.
Use the
button to select Device settings, then press the OK button.
Use the
button to select LAN settings, then press the OK button.
Use the
button to select Print LAN details, then press the OK button.
The following information on the machine's network setting is printed out.
Item | Explanations of the item | Setting |
Wireless LAN | Wireless LAN | Enable/Disable |
Link Status | Status of the Wireless LAN | Active/Inactive |
MAC Address | MAC Address | XX:XX:XX:XX:XX:XX |
SSID | SSID | SSID of the wireless LAN |
Connection Mode | Connection Mode | Infrastructure |
Channel | Channel | XX (1 to 13) |
Encryption | Method of the Encryption | none/WEP/TKIP/AES |
WEP Key Length | WEP Key Length | Inactive/128/64 |
Authentication | Method of the Authentication | none/auto/open/shared/WPA-PSK/WPA2-PSK |
Signal Strength | Signal Strength | 0 to 100 [%] |
TCP/IP Version | TCP/IP Version | IPv4/IPv6 |
IP Address | Selected IP Address | XXX.XXX.XXX.XXX |
Default Gateway | Default Gateway | XXX.XXX.XXX.XXX |
Subnet Mask*1 | Subnet Mask | XXX.XXX.XXX.XXX |
Subnet Prefix Length*2 | Subnet Prefix Length | XXX |
IPsec*3 | IPsec setting | Active |
Security Protocol*3 | Method of the Security Protocol | ESP/ESP & AH/AH |
Printer Name | Printer name | Printer name (Up to 15 characters) |
WSD | WSD setting | Enable/Disable |
WSD Timeout | Timeout | 1/5/10/15/20 [min] |
LPR Protocol | LPR protocol setting | Enable/Disable |
Bonjour | Bonjour setting | Enable/Disable |
Bonjour Service Name | Bonjour service name | Bonjour service name (Up to 52 characters) |
IP Address Filtering | IP Address Filtering | Enable/Disable |
("X" represents an alphanumeric characters.)
*1 Only when IPv4 is selected for TCP/IP settings, the status of the network is printed.
*2 Only when IPv6 is selected on TCP/IP settings, the status of the network is printed.
*3 Only when IPv6 is selected on TCP/IP settings and Active is selected on IPsec settings, the status of the network is printed.
Page top
