You need to prepare: a sheet of A4 or Letter-sized plain paper (including recycled paper)*
* Be sure to use paper that is white and clean on sides.
Make sure that the power is turned on.
Load a sheet of A4 or Letter-sized plain paper in the front tray.
Open the output tray extension, open the paper output tray, then extend the paper output support.
Print the print head alignment sheet.
Select Setup on the HOME screen. The Setup menu screen will appear.
Select Maintenance, then press the OK button. The Maintenance screen will appear.
Select Auto head alignment, then press the OK button.
The confirmation screen will appear.
Confirm the message, select Yes, then press the OK button. The print head alignment sheet will be printed.
Important:
Do not touch any printed part on the print head alignment sheet.
Be careful not to get the print head alignment sheet dirty. If the sheet is stained or wrinkled, it may not be scanned properly.
When the message "Did the patterns print correctly?" appears, confirm that the pattern is printed correctly, select Yes, then press the OK button.
Scan the print head alignment sheet to adjust the print head position.
Confirm the message, then load the print head alignment sheet on the platen glass. Load the print head alignment sheet WITH THE PRINTED SIDE FACING DOWN and align the mark on the upper left corner of the sheet with the alignment mark.
Close the document cover gently, then press the OK button. The machine starts scanning the print head alignment sheet, and the print head position will be adjusted automatically.
Important:
Do not open the document cover or move the print head alignment sheet on the platen glass until adjusting the print head position is complete.
If the error message appears on the LCD, press the OK button to release the error, then take appropriate action.
When the completion message appears, press the OK button. The screen will return to the Maintenance screen.
Remove the print head alignment sheet on the platen glass.
Note:
Press the HOME button to exit Setup and display the HOME screen.
If the print results are still not satisfactory after adjusting the print head position as described above, adjust the print head position manually from the computer.
Aligning the Print Head Position from Your Computer
