Printing Out Network Setting Information
You can print out the network settings of the machine such as its IP address and SSID.
Note: The steps listed below are specific to the MX350 and MX870 printers. For instructions for other models, click here
Make sure that the machine is turned on. Load a sheet of A4 or Letter-sized plain paper.
Press the Setup button.
Select
Device settings, then press the OK button.
Use the
button to select LAN settings, then press the OK button.
Use the
button to select Confirm LAN settings, then press the OK button.
Use the
button to select Print LAN details, then press the OK button to confirm the selection.
Use the
button to select Yes, then press the OK button to start printing.
The machine starts printing the network setting information.
The following information on the machine's network (WLAN or LAN) settings is printed out.
WLAN setting list
Items | Setting (IPv4) | Setting (IPv6) |
Link Status | Active/Inactive | Active/Inactive |
SSID | XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX | XXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXX |
Communication mode | Infrastructure | Infrastructure |
Channel | XX | XX |
Wireless LAN security | Disable/WEP(64bit)/WEP(128bit)/WPA-PSK(TKIP)/WPA-PSK(AES)/WPA2-PSK(TKIP)/WPA2-PSK(AES) | Disable/WEP(64bit)/WEP(128bit)/WPA-PSK(TKIP)/WPA-PSK(AES)/WPA2-PSK(TKIP)/WPA2-PSK(AES) |
IP address | XXX. XXX. XXX. XXX | XXXX: XXXX: XXXX: XXXX: XXXX: XXXX: XXXX: XXXX |
Subnet mask | XXX. XXX. XXX. XXX | - |
Subnet prefix length | - | XXX |
Default gateway | XXX. XXX. XXX. XXX | XXXX: XXXX: XXXX: XXXX: XXXX: XXXX: XXXX: XXXX |
MAC address | XX:XX:XX:XX:XX:XX | XX:XX:XX:XX:XX:XX |
IPsec settings | - | Enable (ESP)/Enable (ESP & AH)/Enable (AH)/Disable |
Pre-shared key | - | XXXXXXXXXXX |
Printer name | XXXXXXXXXXXXXXX | XXXXXXXXXXXXXXX |
Bonjour service name | Canon MX870 series _XXXXXXXXXXXX, or Canon MX350 series _XXXXXXXXXXXX | Canon MX870 series _XXXXXXXXXXXX , or Canon MX350 series _XXXXXXXXXXXX |
LAN setting list
Bonjour service name | Canon MX870 series _XXXXXXXXXXXX or Canon MX350 series _XXXXXXXXXXXX | Canon MX870 series _XXXXXXXXXXXX Canon MX350 series _XXXXXXXXXXXX |
Page top
