Salesforce
Printing Out the MG7120 LAN Details
« Go Back
Information
TitlePrinting Out the MG7120 LAN Details
URL NameART142758
Description
This article explains how to print a Network Configuration Page for the PIXMA MG7120.  An example of this page is attached to this article.
Solution
Printing Out Network Setting Information
Note: The steps listed below are specific to the MG7120.  For instructions for other models, click here
You can print out the network settings of the machine such as its IP address and SSID.
Important
  • This print out contains valuable information about your computer. Handle it with care.
    1. Make sure that the machine is turned on
    2. Load a sheet of A4 or Letter-sized plain paper.
    3. Flick the HOME screen, then tap Setup.
      Using the Operation Panel
      The menu screen is displayed.
    4. Tap Device settings.
    5. Tap LAN settings.
    6. Tap Confirm LAN settings.
    7. Tap Print LAN details.
    8. Tap Yes.
      The machine starts printing the network setting information.
      The following information on the machine's network setting is printed out.
      Item
      Explanations of the item
      Setting
      Wireless LAN
      Wireless LAN
      Enable/Disable
      Connection
      Status of the Wireless LAN
      Active/Inactive
      MAC Address
      MAC Address
      XX:XX:XX:XX:XX:XX
      SSID
      SSID
      SSID of the wireless LAN
      Communication Mode
      Communication Mode
      Infrastructure
      Channel
      Channel
      XX (1 to 13)
      Encryption
      Method of the Encryption
      none/WEP/TKIP/AES
      WEP Key Length
      WEP Key Length
      Inactive/128/64
      Authentication
      Method of the Authentication
      none/auto/open/shared/WPA-PSK/WPA2-PSK
      Signal Strength
      Signal Strength
      0 to 100 [%]
      TCP/IP Version
      TCP/IP Version
      IPv4 & IPv6/IPv4
      IPv4 IP Address
      Selected IP Address (IPv4)
      XXX.XXX.XXX.XXX
      IPv4 Default Gateway
      Default Gateway (IPv4)
      XXX.XXX.XXX.XXX
      Subnet Mask
      Subnet Mask
      XXX.XXX.XXX.XXX
      IPv6 IP Address *1
      Selected IP Address (IPv6)
      XXXX:XXXX:XXXX:XXXX
      XXXX:XXXX:XXXX:XXXX
      IPv6 Default Gateway *1
      Default Gateway (IPv6)
      XXXX:XXXX:XXXX:XXXX
      XXXX:XXXX:XXXX:XXXX
      Subnet Prefix Length*1
      XXX
      IPsec*2
      IPsec setting
      Active
      Security Protocol*2
      Method of the Security Protocol
      ESP/ESP & AH/AH
      Wireless LAN DRX
      Discontinuous reception (wireless LAN)
      Enable/Disable
      Wired LAN
      Wired LAN
      Enable/Disable
      Connection
      Status of the Wired LAN
      Active/Inactive
      MAC Address
      MAC Address
      XX:XX:XX:XX:XX:XX
      TCP/IP Version
      TCP/IP Version
      IPv4 & IPv6/IPv4
      IPv4 IP Address
      XXX.XXX.XXX.XXX
      XXX.XXX.XXX.XXX
      Subnet Mask
      Subnet Mask
      XXX.XXX.XXX.XXX
      IPv6 IP Address *1
      XXXX:XXXX:XXXX:XXXX
      XXXX:XXXX:XXXX:XXXX
      XXXX:XXXX:XXXX:XXXX
      XXXX:XXXX:XXXX:XXXX
      XXX
      IPsec*2
      IPsec setting
      Active
      Security Protocol*2
      ESP/ESP & AH/AH
      Wired LAN DRX
      Discontinuous reception (wired LAN)
      Enable/Disable
      Other Settings
      Other settings
      Printer Name
      Printer name
      Printer name (Up to 15 characters)
      Shared Memory Card
      Memory card sharing
      Enable/Disable
      WSD
      WSD setting
      Enable/Disable
      WSD Timeout
      Timeout
      1/5/10/15/20 [min]
      LPR Protocol
      LPR protocol setting
      Enable/Disable
      Bonjour
      Bonjour setting
      Enable/Disable
      Bonjour Service Name
      Bonjour service name
      Bonjour service name (Up to 52 characters)
      PictBridge Commun.
      PictBridge Communication
      Enable/Disable
      DNS Server
      Getting DNS Server automatically
      Auto/Manual
      Primary Server
      Primary server address
      XXX.XXX.XXX.XXX
      Secondary Server
      Secondary server address
      XXX.XXX.XXX.XXX
      Proxy Server
      Proxy Server setting
      Enable/Disable
      Proxy Port
      Specifying Proxy Port
      1 to 65535
      Proxy Address
      Proxy Address
      XXXXXXXXXXXXXXXXXXXX
      IP Address Filtering
      Enable/Disable
      ("XX" represents alphanumeric characters.)
      *1 Only when IPv6 is activated, the status of the network is printed.
      *2 Only IPv6 and the IPsec setting are activated, the status of the network is printed.
MG7120 Page
Powered by
