Salesforce
Printing the Network Information (LAN Details) - MX452/459
« Go Back
Information
TitlePrinting the Network Information (LAN Details) - MX452/459
URL NameART142788
Description
This article explains how to print a Network Configuration Page (also known as a LAN details page).
Solution
Note: The steps listed below are specific to the MX452 / MX459 printers.  For instructions for other models, click here
Make sure that the machine is turned on.
  1.  Press the Setup button.
  2.  Use the LEFT RIGHT button to select Device settings, then press the OK button.
  3.  Use the LEFT RIGHT button to select LAN settings then press the OK button.
  4.  Use the LEFT RIGHT button to select Print LAN details then press the OK button.
The Network Configuration Page will be printed.
Powered by
