Note: The steps listed below are specific to the MX722. For instructions for other models, click here
Make sure that the machine is turned on. Load a sheet of A4 or Letter-sized plain paper.
Press the Menu button
Select
Setup , then press the OK button.
Select
Device settings, then press the OK button.
Use the
button to select LAN settings, then press the OK button.
Use the
button to select Confirm LAN settings, then press the OK button.
Use the
button to select Print LAN details, then press the OK button to confirm the selection.
Use the
button to select Yes, then press the OK button to start printing.
The machine starts printing the network setting information.
