Note: The steps listed below are specific to the MX922. For instructions for other models, click here
Steps
- Make sure the printer is turned on, and there's a sheet of A4 or Letter-sized paper loaded.
- Press the Menu button.
- Press the right arrow and the down arrow
to select
Setup, then press OK. - Select
Device settings, then press OK. - Use the arrow buttons
to select LAN settings, then press OK. - Use the arrow buttons
to select Confirm LAN settings, then press OK. - Use the arrow buttons
to select Print LAN details, then press OK. - Use the arrow buttons
to select Yes, then press OK to start printing. - The printer prints a page containing your network configuration details. See document below for an example.
The following information on the machine's network setting is printed out.
Item
Explanations of the item
Setting
Wireless LAN
Wireless LAN
Enable/Disable
Connection
Status of the Wireless LAN
Active/Inactive
MAC Address
MAC Address
XX:XX:XX:XX:XX:XX
SSID
SSID
SSID of the wireless LAN
Communication Mode
Communication Mode
Infrastructure
Channel
Channel
XX (1 to 13)
Encryption
Method of the Encryption
none/WEP/TKIP/AES
WEP Key Length
WEP Key Length
Inactive/128/64
Authentication
Method of the Authentication
none/auto/open/shared/WPA-PSK/WPA2-PSK
Signal Strength
Signal Strength
0 to 100 [%]
TCP/IP Version
TCP/IP Version
IPv4 & IPv6/IPv4
IPv4 IP Address
Selected IP Address (IPv4)
XXX.XXX.XXX.XXX
IPv4 Default Gateway
Default Gateway (IPv4)
XXX.XXX.XXX.XXX
Subnet Mask
Subnet Mask
XXX.XXX.XXX.XXX
IPv6 IP Address *1
Selected IP Address (IPv6)
XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX
IPv6 Default Gateway *1
Default Gateway (IPv6)
Subnet Prefix Length*1
XXX
IPsec*2
IPsec setting
Active
Security Protocol*2
Method of the Security Protocol
ESP/ESP & AH/AH
Wireless LAN DRX
Discontinuous reception (wireless LAN)
Enable/Disable
Wired LAN
Wired LAN
Enable/Disable
Connection
Status of the Wired LAN
Active/Inactive
MAC Address
MAC Address
XX:XX:XX:XX:XX:XX
TCP/IP Version
TCP/IP Version
IPv4 & IPv6/IPv4
IPv4 IP Address
XXX.XXX.XXX.XXX
XXX.XXX.XXX.XXX
Subnet Mask
Subnet Mask
XXX.XXX.XXX.XXX
IPv6 IP Address *1
XXX
IPsec*2
IPsec setting
Active
Security Protocol*2
ESP/ESP & AH/AH
Wired LAN DRX
Discontinuous reception (wired LAN)
Enable/Disable
Other Settings
Other settings
Printer Name
Printer name
Printer name (Up to 15 characters)
WSD
WSD setting
Enable/Disable
WSD Timeout
Timeout
1/5/10/15/20 [min]
LPR Protocol
LPR protocol setting
Enable/Disable
Bonjour
Bonjour setting
Enable/Disable
Bonjour Service Name
Bonjour service name
Bonjour service name (Up to 52 characters)
PictBridge Commun.
PictBridge Communication
Enable/Disable
DNS Server
Getting DNS Server automatically
Auto/Manual
Primary Server
Primary server address
XXX.XXX.XXX.XXX
Secondary Server
Secondary server address
XXX.XXX.XXX.XXX
Proxy Server
Proxy Server setting
Enable/Disable
Proxy Port
Specifying Proxy Port
1 to 65535
Proxy Address
Proxy Address
XXXXXXXXXXXXXXXXXXXX
IP Address Filtering
Enable/Disable
("XX" represents alphanumeric characters.)
*1 Only when IPv6 is activated, the status of the network is printed.
*2 Only IPv6 and the IPsec setting are activated, the status of the network is printed.
