Note: The steps listed below are specific to the MG4220. For instructions for other models, click here
Make sure that the machine is turned on.
Load a sheet of A4 or Letter-sized plain paper.
Select
Setup on the HOME screen.
Select
Device settings, then use the OK button to confirm the selection.
The Device settings screen is displayed.
Use the
button to select LAN settings, then press the OK button to confirm the selection.
Use the
button to select Confirm LAN settings, then press the OK button to confirm the selection.
Use the
button to select Print LAN details, then press the OK button to confirm the selection.
Use the
button to select Yes, then press the OK button to start printing.
The machine starts printing the network setting information.
