Cleaning the Print Heads from Your Computer - Windows
The print head cleaning function allows you to clear up clogged print head nozzle. Perform print head cleaning if printing is faint or a specific color fails to print, even though there is enough ink.
The procedure for cleaning the print head is as follows:
Cleaning
Open the printer driver setup window.
Click Cleaning on the Maintenance tab.
When the Print Head Cleaning dialog box opens, select the ink group for which cleaning is to be performed.
Click Initial Check Items to display the items you need to check before performing cleaning.
Make sure that the printer is on and then click Execute.
Print head cleaning starts.
Complete cleaning.
The Nozzle Check dialog box opens after the confirmation message.
Check the results.
To check whether the print quality has improved, click Print Check Pattern. To cancel the check process, click Cancel.
If cleaning the head once does not resolve the print head problem, clean it once more.
Important
- Cleaning consumes a small amount of ink.
- Cleaning the print head frequently will rapidly deplete your printer's ink supply. Consequently, perform cleaning only when necessary.
Deep Cleaning
Deep Cleaning is more thorough than cleaning. Perform deep cleaning when two Cleaning attempts do not resolve the print head problem.
Click Deep Cleaning on the Maintenance tab.
When the Deep Cleaning dialog box opens, select the ink group for which deep cleaning is to be performed.
Click Initial Check Items to display the items you need to check before performing deep cleaning.
Click OK when the confirmation message appears.
Print head deep cleaning starts.
Complete deep cleaning.
Check the results.
Important
- Deep Cleaning consumes a larger amount of ink than Cleaning.
Note
- If there is no sign of improvement after Deep Cleaning, switch off the printer, wait 24 hours, and then perform Deep Cleaning again. If there is still no sign of improvement, the ink may have run out or the print head may be worn.
For support and service options, sign into (or create) your Canon Account from the link below.My Canon Account
