Salesforce
Printing Out Network Setting Information (LAN details)- PRO-100, PRO-10
« Go Back
Information
TitlePrinting Out Network Setting Information (LAN details)- PRO-100, PRO-10
URL NameART153123
Description
This article explains how to print a Network Setting Page.  An example of the Lan Details page is attached to this article.
Solution
You can print out the network settings of the printer such as its IP address and SSID.
This information can help you with troubleshooting. For example, if you're experiencing slow printing speeds with a wireless network connection, you can see the signal strength of your printer's connection to your network.
The steps listed below are specific to the PRO-10 and PRO-100 printers.  For instructions for other models, click here
This printout contains valuable information about your computer. Handle it with care.
  1. Make sure that the printer is turned on.
  2. Load a sheet of A4 or Letter-sized plain paper.
  3. Press and hold the RESUME/CANCEL button until the POWER lamp flashes 6 times.
  4. Release the RESUME/CANCEL button.
The printer starts printing the network setting information.
The following information on the printer's network setting is printed out.
Item
Explanations of the item
Setting
Wireless LAN
Wireless LAN
Enable/Disable
Connection
Status of the Wireless LAN
Active/Inactive
MAC Address
MAC Address
XX:XX:XX:XX:XX:XX
SSID
SSID
SSID of the wireless LAN
Communication Mode
Communication Mode
Infrastructure
Channel
Channel
XX (1 to 13)
Encryption
Method of the Encryption
none/WEP/TKIP/AES
WEP Key Length
WEP Key Length
Inactive/128/64
Authentication
Method of the Authentication
none/auto/open/shared/WPA-PSK/WPA2-PSK
Signal Strength
Signal Strength
0 to 100 [%]
TCP/IP Version
TCP/IP Version
IPv4 & IPv6/IPv4
IPv4 IP Address
Selected IP Address (IPv4)
XXX.XXX.XXX.XXX
IPv4 Default Gateway
Default Gateway (IPv4)
XXX.XXX.XXX.XXX
Subnet Mask
Subnet Mask
XXX.XXX.XXX.XXX
IPv6 IP Address *1
Selected IP Address (IPv6)
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
IPv6 Default Gateway *1
Default Gateway (IPv6)
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
Subnet Prefix Length*1
XXX
IPsec*2
IPsec setting
Active
Security Protocol*2
Method of the Security Protocol
ESP/ESP & AH/AH
WPS PIN CODE
WPS PIN code
XXXXXXXX
Wireless LAN DRX
Discontinuous reception (wireless LAN)
Enable/Disable
Wired LAN
Wired LAN
Enable/Disable
Connection
Status of the Wired LAN
Active/Inactive
MAC Address
MAC Address
XX:XX:XX:XX:XX:XX
TCP/IP Version
TCP/IP Version
IPv4 & IPv6/IPv4
IPv4 IP Address
XXX.XXX.XXX.XXX
XXX.XXX.XXX.XXX
Subnet Mask
Subnet Mask
XXX.XXX.XXX.XXX
IPv6 IP Address *1
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
XXX
IPsec*2
IPsec setting
Active
Security Protocol*2
ESP/ESP & AH/AH
Wired LAN DRX
Discontinuous reception (wired LAN)
Enable/Disable
Other Settings
Other settings
Printer Name
Printer name
Printer name (Up to 15 characters)
WSD
WSD setting
Enable/Disable
WSD Timeout
Timeout
1/5/10/15/20 [min]
LPR Protocol
LPR protocol setting
Enable/Disable
Bonjour
Bonjour setting
Enable/Disable
Bonjour Service Name
Bonjour service name
Bonjour service name (Up to 52 characters)
IP Address Filtering
Enable/Disable
("XX" represents alphanumeric characters.)
*1 Only when IPv6 is activated, the status of the network is printed.
*2 Only IPv6 and the IP sec setting are activated; the status of the network is printed.
Powered by
