Salesforce
Print Out Your Wireless Details - PIXMA MG3620
« Go Back
Information
TitlePrint Out Your Wireless Details - PIXMA MG3620
URL NameART162693
Description
Learn how to get a printout of your wireless network (LAN) information for the PIXMA MG3620.
An example of this information can be found here.
Solution
You may occasionally need information about your Wi-Fi® connection, such as your machine's IP address or signal strength.
Follow these steps to get a printout similar to the sample provided below.
Note These steps are specific to the PIXMA MG3620. Get instructions for other printer models.
  1. Make sure that the printer is turned on.
  2. Load two sheets of A4 or Letter-size plain paper.
  3. Press and hold the Wi-Fi button and release it when the ON light flashes.
  4. Press the Wi-Fi button again. The machine starts printing the network setting information.
    Sample printout
    Item
    Description
    Setting
    Product Information
    Product information
    Product Name
    Product name
    XXXXXXXX
    ROM Version
    ROM version
    XXXXXXXX
    Serial Number
    Serial number
    XXXXXXXX
    Default Password *4
    Default Password (to access Remote UI)
    XXXXXXXX
    Wireless LAN
    Wireless LAN
    Enable/Disable
    MAC Address
    MAC address
    XX:XX:XX:XX:XX:XX
    WPS PIN CODE
    WPS PIN code
    XXXXXXXX
    Infrastructure
    Infrastructure
    Enable/Disable
    Connection
    Connection status
    Active/Inactive
    SSID
    SSID
    Wireless LAN SSID
    Channel *1
    Channel
    XX (1 to 11)
    Encryption
    Encryption method
    None/WEP/TKIP/AES
    WEP Key Length
    WEP key length (bits)
    Inactive/128/64
    Authentication
    Authentication method
    None/auto/open/shared/WPA-PSK/WPA2-PSK
    Signal Strength
    Signal strength
    0 to 100 [%]
    TCP/IPv4
    TCP/IPv4
    Enable
    IP Address
    IP address
    XXX.XXX.XXX.XXX
    Subnet Mask
    Subnet mask
    XXX.XXX.XXX.XXX
    Default Gateway
    Default gateway
    XXX.XXX.XXX.XXX
    TCP/IPv6
    TCP/IPv6
    Enable/Disable
    IP Address *2
    IP address
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Subnet Prefix Length *2
    Subnet prefix length
    XXX
    Default Gateway *2
    Default gateway
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    IPsec *3
    IPsec setting
    Active
    Security Protocol *3
    Security method
    ESP/ESP & AH/AH
    Access Point Mode
    Access point mode
    Enable/Disable
    Connection
    Connection status
    Active/Inactive
    SSID
    SSID
    Access Point Mode SSID
    Password
    Password
    Password of the access point mode (8 to 10 alphanumeric characters)
    Channel
    Channel
    3
    Encryption
    Encryption method
    AES
    Authentication
    WPA2-PSK
    TCP/IPv4
    TCP/IPv4
    Enable
    IP Address
    IP address
    XXX.XXX.XXX.XXX
    Subnet Mask
    Subnet mask
    XXX.XXX.XXX.XXX
    Default Gateway
    Default gateway
    XXX.XXX.XXX.XXX
    TCP/IPv6
    TCP/IPv6
    Enable/Disable
    IP Address *2
    IP address
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    XXX
    Default Gateway *2
    Default gateway
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    IPsec *3
    IPsec setting
    Active
    Security method
    Other Settings
    Other settings
    Printer Name
    Printer name
    Printer name (Up to 15 alphanumeric characters)
    WSD Printing
    WSD printing setting
    Enable/Disable
    WSD Timeout
    Timeout
    1/5/10/15/20 [min]
    LPD Printing
    LPD printing setting
    Enable/Disable
    Bonjour
    Bonjour setting
    Enable/Disable
    Bonjour Service Name
    Bonjour service name
    Bonjour service name (Up to 52 alphanumeric characters)
    PictBridge Commun.
    PictBridge communication
    Enable/Disable
    DNS Server
    Obtain DNS server address automatically
    Auto/Manual
    Primary Server
    Primary server address
    XXX.XXX.XXX.XXX
    Secondary Server
    Secondary server address
    XXX.XXX.XXX.XXX
    Proxy Server
    Proxy server setting
    Enable/Disable
    Proxy Address
    Proxy address
    XXXXXXXXXXXXXXXXXXXX
    Proxy Port
    Proxy port specification
    1 to 65535
    ("XX" represents alphanumeric characters.)
    *1 Channel may range from 1 to 11 depending on country or region of purchase.
    *2 Network status is only printed when IPv6 is enabled.
    *3 Network status is only printed when IPv6 and IPsec settings are enabled.
    *4 Firmware version 3.000 or later required.
For support and service options, sign into (or create) your Canon Account from the link below.
My Canon Account
Powered by
