Salesforce
Print Out Wireless Network Information - PIXMA MG3020, MG3022
« Go Back
Information
TitlePrint Out Wireless Network Information - PIXMA MG3020, MG3022
URL NameART166531
Description
Learn how to print out the wireless network (LAN) settings stored in the printer.
Solution
Note The steps below are for PIXMA MG3020 and MG3022 printers. Get instructions for other printer models.
Follow these steps from the operation panel of the printer.
  1. Turn the printer ON.
  2. Load two sheets of A4 or Letter-sized plain paper.
  3. Press and hold the Wi-Fi® button and release it when Wi-Fi lamp flashes.
  4. Press the Color button.
  5. Press the Wi-Fi button twice.
  6. Press the Color or Black button.
Network information similar to what you see below prints out. (Some setting values may not display depending on the printer settings.)
Caution The network settings printout contains important information about your network. Handle it with care.
Sample printout
Item
Description
Setting
Product Information
Product information
Product Name
Product name
XXXXXXXX
ROM Version
ROM version
XXXXXXXX
Serial Number
Serial number
XXXXXXXX
Wireless LAN
Wireless LAN
Enable/Disable
WPS PIN CODE
WPS PIN code
XXXXXXXX
Infrastructure
Infrastructure
Enable/Disable
MAC Address
MAC address
XX:XX:XX:XX:XX:XX
Connection
Connection status
Active/Inactive
SSID
Wireless network name
Channel
Channel
XX (1 to 11)
Encryption
Encryption method
None/WEP/TKIP/AES
WEP Key Length
WEP key length (bits)
Inactive/128/64
Authentication
Authentication method
None/auto/open/shared/WPA-PSK/WPA2-PSK
Signal Strength
Signal strength
0 to 100 [%]
TCP/IPv4
TCP/IPv4
Enable
IP Address
IP address
XXX.XXX.XXX.XXX
Subnet Mask
Subnet mask
XXX.XXX.XXX.XXX
Default Gateway
Default gateway
XXX.XXX.XXX.XXX
TCP/IPv6
TCP/IPv6
Enable/Disable
Link Local Address
Link local address
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
Link Local Prefix Length
Link local prefix length
XXX
Stateless Address1
Stateless address 1
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
Stateless Prefix Length1
Stateless prefix length 1
XXX
Stateless Address2
Stateless address 2
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
Stateless Prefix Length2
Stateless prefix length 2
XXX
Stateless Address3
Stateless address 3
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
Stateless Prefix Length3
Stateless prefix length 3
XXX
Stateless Address4
Stateless address 4
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
Stateless Prefix Length4
Stateless prefix length 4
XXX
Default Gateway1
Default gateway 1
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
Default Gateway2
Default gateway 2
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
Default Gateway3
Default gateway 3
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
Default Gateway4
Default gateway 4
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
IPsec
IPsec setting
Active
Security Protocol
Security method
ESP/ESP & AH/AH
Access Point Mode
Access Point Mode / Wireless Direct
Enable/Disable
MAC Address
MAC address
XX:XX:XX:XX:XX:XX
Connection
Connection status
Active/Inactive
SSID
Wireless Direct network name
Password
Password
Wireless Direct password (10 alphanumeric characters)
Channel
Channel
3
Encryption
Encryption method
AES
Authentication
WPA2-PSK
TCP/IPv4
TCP/IPv4
Enable
IP Address
IP address
XXX.XXX.XXX.XXX
Subnet Mask
Subnet mask
XXX.XXX.XXX.XXX
Default Gateway
Default gateway
XXX.XXX.XXX.XXX
TCP/IPv6
TCP/IPv6
Enable/Disable
Link Local Address
Link local address
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
XXX
IPsec
IPsec setting
Active
Security Protocol
Security method
Other Settings
Other settings
Printer Name
Printer name
Printer name (Up to 15 alphanumeric characters)
WSD Printing
WSD printing setting
Enable/Disable
WSD Timeout
Timeout
1/5/10/15/20 [min]
LPD Printing
LPD printing setting
Enable/Disable
RAW Printing
RAW printing setting
Enable/Disable
Bonjour
Bonjour setting
Enable/Disable
Bonjour Service Name
Bonjour service name
Bonjour service name (Up to 52 alphanumeric characters)
LLMNR
LLMNR setting
Enable/Disable
SNMP
SNMP setting
Enable/Disable
PictBridge Commun.
PictBridge Communication
Enable/Disable
DNS Server
Obtain DNS server address automatically
Auto/Manual
Primary Server
Primary server address
XXX.XXX.XXX.XXX
Secondary Server
Secondary server address
XXX.XXX.XXX.XXX
Proxy Server
Proxy server setting
Enable/Disable
Proxy Address
Proxy address
XXXXXXXXXXXXXXXXXXXX
Proxy Port
Proxy port specification
1 to 65535
Cert. Fingerprt(SHA-1)
Certificate fingerprint(SHA-1)
XXXXXXXX XXXXXXXX XXXXXXXX
XXXXXXXX XXXXXXXX
Cert. Fingerprt(SHA-256)
Certificate fingerprint(SHA-256)
XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX
("XX" represents alphanumeric characters.)
Powered by
